When I turn the camera on I see a msg on the screen that says Card not initialized. I do not see instructions in the maual that tells me how to initialize an xD card, only that the card may need to be formatted.
-   My Fuji Fine Pix S3000 just developed the "card not initialized" message... I've had this camera for over 3 years. Does the card just "go bad"? How do I fix it??
Turn the camera viewer on (on your finepix 3800, it is the middle position where you preview photos). Press the "menu" button and you will be presented with four options, and the top option is FORMAT. Select format and your card will be usable again. Two things to keep in mind. Any pictures on the card will be lost, and when you press the menu button as I described it may take a few seconds before those four options appear. As an FYI, the most common cause of the card needing to be reformatted is when the pictures are loaded to a MAC computer and the USB cable is pulled before you eject the camera.
the fugi film 3800 camera is not installed into control panel it only gives option for a mx 250 fugi...
(More)
THE FUGI FILM 3800 CAMERA IS NOT INSTALLED INTO CONTROL PANEL IT ONLY GIVES OPTION FOR A MX 250 FUGI FILM CAMERA fINE PIX DISC IS INSTALLED, BUT WONT TALK TO CAMERA USB CONNECTED , DCS IS ON CAMERA AND CHIP IS READABLE FROM CAMERA WHAT TO DO?
does not always shoot a picture when pressing the shutter button. sometimes the flash does not fire...
(More)
does not always shoot a picture when pressing the shutter button. sometimes the flash does not fire even if it is open. The ring around the lense is coming loose about half of the circumference and I am not sure if this is the cause of my recent problems
