1999 Honda Accord Logo
john belanger Posted on Mar 20, 2017
My 99 accord lx has an intermmitent starting problem. It idles irracatically & stalls. then when warm sometimes it won't start. the evac( I think that's what it's called it's a par
My 99 accord lx has an intermmitent starting problem. It idles irracatically & stalls. then when warm sometimes it won't start. the evac( I think that's what it's called it's a part on the back of the engine where the vacuum hoses go into it's a vtec 4cyl. engine) has come up on check engine light it's getting plenty of fuel & spark, just tuned up but it'll be running fine then start idling up & down then stall. then it won't start & not every time it'll crank & crank I smell fuel & then finally it starts like it's been flooded. i've been told the vacuum wouldn't cause this but wouldn't it be possible with the erratic idling then stalling problems?
John M. Douglass
Level 1:
Habit-Forming:
New Friend:
  • Contributor 39 Answers
  • Posted on May 02, 2017
 John M. Douglass
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
39
Questions
0
Helped
16678
Points
73
I had a similar issue, with my 96 civic. Get a leak down test done. For me, it was bent valves.
3 Related Answers
Anonymous
  • 178 Answers
  • Posted on Sep 18, 2008
SOURCE: rough idle stalls at low rpm's
hello first check your idle with the car running foot on brake see were your rpm reading is if your below 500rpm check your label underhood for your curb idle setting second see if theres a adjustment screw you can increase were your gas cable lever rest against your set screw underhood if you feel confident enough remove your iac motor idle air control valve if the bore were the end of the pintle extracts out to close has varnish builup our carbon it will stick creating vacuum leak type senario causing stalling rough idle sometimes even no start conditions good luck
Anonymous
  • 120 Answers
  • Posted on Dec 21, 2008
SOURCE: 1992 honda accord lx starts okay then idles down wants to stall
a good tune up shall solve your problem. replace the ff: spark plug. spark plug wires, air filter, fuel filter, and an oil change, good luck!
duane_wong
Duane Wong
  • 6826 Answers
  • Posted on Oct 29, 2010
SOURCE: 4cyl 2000 honda accord engine stalls while idling,
check for spark and fuel after it dies.
If there is spark but no fuel, then the fuel pump may be bad or a clogged fuel filter.
If there is fuel but not spark, then the ignition control module or the ignition coil could be bad.
Also, check that the timing belt is timing the engine correctly.
Timing Belt & Balancer Belt
Removal & Installation
2.3L Engine
To Remove:
  1. Record anti-theft code for radio.
  2. Disconnect battery negative cable then positive cable.
  3. Turn crankshaft pulley until TDC is achieved.
  4. Raise and safely support vehicle.
  5. Remove front tire assembly.
  6. Remove splash shield.
  7. Remove power steering belt.
  8. Remove alternator and alternator bracket.
  9. Safely support engine under oil pan.
    Upper bracket removal
  10. Remove stop, detach ground cable and remove upper bracket.
  11. Remove cylinder head cover.
  12. Remove upper cover.
  13. Remove dipstick and tube assembly.
  14. Remove crankshaft pulley.
  15. Remove adjusting nut rubber seal and remove lower cover.
    Timing belt/balancer belt removal
  16. Loosen adjusting nut 1 turn.
  17. Push up on balancer belt tensioner to relieve belt tension.
  18. Push down on timing belt tensioner to relieve belt tension.
  19. Tighten adjusting nut 1 turn.
  20. Remove balancer belt and timing belt.
To Install:
NOTE: Clean balancer belt drive pulley, timing belt pulleys and
upper/lower timing cover prior to belt installation.
  1. Set timing belt drive pulley to TDC by aligning dimple on pulley with dimple
    on oil pump.
  2. Set camshaft pulley to TDC so that "UP" mark is at top and grooves align
    with top of cylinder head.
    Timing belt installation
  3. Starting with driver pulley, install timing belt in a counterclockwise
    sequence.
  4. Loosen and ten retighten adjusting nut.
  5. Install balancer belt drive pulley.
    NOTE: Inspect rubber seal on lower cover and replace as necessary.
  6. Install lower cover.
  7. Install crankshaft pulley and bolt.
  8. Rotate crankshaft pulley counterclockwise several times to seat belt.
  9. Loosen adjusting nut 1 turn.
  10. Rotate crankshaft counterclockwise 3 teeth on camshaft pulley.
  11. Tighten adjusting nut to 33 ft lb (44 Nm).
  12. Turn crankshaft pulley until TDC is achieved.
  13. Ensure that camshaft pulley "UP" mark is at top and grooves align with top
    of cylinder head.
  14. Remove crankshaft pulley and lower cover.
  15. Rotate crankshaft to TDC again and lock timing belt adjuster arm with a 6 mm
    timing cover bolt.
  16. Loosen adjuster nut 1 turn and ensure that belt tensioner freely moves.
  17. Push tensioner up and tighten adjusting nut.
    Balancer shaft alignment
  18. Remove bolt and washer from maintenance hole.
  19. Using a 6 X 100 mm bolt, scribe a mark 2.9 in (74 mm) from end.
  20. Insert bolt into maintenance hole and hole in balancer shaft.
  21. Install bolt up to scribed line.
  22. Align groove on balancer shaft with pointer on oil pump housing.
  23. Install balancer belt and loosen adjusting nut 1 turn to tension.
  24. Retighten bolt.
  25. Remove bolt from maintenance hole and install bolt and washer. Tighten to
    22 ft lb (29 Nm).
  26. Reinstall crankshaft pulley.
  27. Loosen adjusting nut 1 turn.
  28. Rotate crankshaft pulley counterclockwise 1 turn and tighten adjusting nut.
  29. Remove bolt from timing belt adjuster arm.
  30. Remove crankshaft pulley.
  31. Install lower cover.
  32. Install seal at adjusting nut.
    NOTE: Crankshaft pulley, bolt and washer must be cleaned prior to
    installation.
  33. Lubricate crankshaft pulley bolt between head and washer and bolt threads
    with clean engine oil.
    CAUTION
    Do not use impact wrench to perform
    following step.
  34. Install crankshaft pulley and tighten bolt using special tools to 181 ft
    lb (245 Nm)
  35. Install dipstick/tube assembly.
  36. Install upper cover. Tighten bolts to 9 ft lb (12 Nm).
  37. Install cylinder head cover.
  38. Install alternator bracket and alternator.
  39. Install power steering pump belt and alternator belt.
    Upper bracket installation
  40. Install upper bracket and tighten fasteners in proper numbered sequence.
  41. Install stop.
  42. Install battery and enter radio anti-theft code.
I have a 2006 2.2 liter Chevy HHR and it will start up but it randomly, cold or warmed up starts idling low and sporadically and when the throttle is applied it’s like an anchor has been thrown out and...
Check the problem with the help of service and repair manual this manual will provide you step by step help to locate and fix the problem easily and you will get the manual from the given link https://toolsnyou.com
Why it stalls at stops and low speeds
accord stalling on every stop. (1/2) - EricTheCarGuy ...
www.ericthecarguy.com/.../8.../46884-accord-stalling-on-every-stop
The car runs good but stalls every time i come to a stop. ... a stop then it diesagain.only on the stops does the idle drop very low to the point of stalling.what ... only when I start slowing down and come to a complete stop RPM's go down and the cardies. ... The popular Honda Civic and Accord vehicles share many powertrain ...
1998 Honda Accord loses rpm/ stalls coming to a stop ...
honda-tech.com/honda-accord.../1998-honda-accord-loses-rpm-stalls-co...
Jan 10, 2013 - I just bought a 1998 4 cyl 2.3 L Honda Accord two days ago. ... 1998Honda Accord loses rpm/ stalls coming to a stop. .... Is clockwise high idle or low idle? all in all i probable rotated counterclockwide 1.5 or 2 turns. maybe this ...
1999 Accord, 130k+, stalls when slowing to a stop - Honda Accord ...
www.hondaaccordforum.com > ... > General > General Tech Help
Mar 10, 2010 - My fiancee's '99 Accord EX Coupe 4-cylinder automatic, with 130,000+ miles, has recently (in .... No low RPM & feeling like it's GOING TO stall.
99 Honda Accord - Strange Stalling Issues! HELP!
https://www.2carpros.com/.../1999-honda-accord-99-strange-stalling-issu...
My 1999 Honda Accord is having sporadic stalling problems. I've noticed a pattern. Itstalls while going slow speeds and stop and go traffic, etc. The engine just ...
Stalling or Low Engine Idle Speed Due to Dirty ... - Repair
When I start my 1996 Honda accord the engine seems to sputter rpm gauge revs up on its own and spits and sputters as I'm driving down the road
My sputtering & stalling 1993 Honda Accord - YouTube
? 2:12
https://www.youtube.com/watch?v=Ki2H9aq8Xis
Jun 23, 2011 - Uploaded by mdpbfly
My sputtering & stalling 1993 Honda Accord ... 1996 Acura Integra, hesitation accelerating & misfire. ... 1993 Honda Accord Start Up and Review 2.2 L 4-Cylinder ... SIR B16A Engine sputter/ power loss at higher RPM - Duration: 1:14. by ... 1994 Honda Civic Check Engine Light Code Retrieval Tutorial ...
All comments on How To Solve Honda Idle Problems ...
https://www.youtube.com/all_comments?v=L788jKEVblY
What should I do if once I turn on my Ac my idle drops as if it's gonna die, and .... to a complete stop the rpms start going up and the car accelerates on its own. ... Honda Accord LX, and my Honda just started sputtering in idle. check engine .... My cousin replaced my radiator on my 90 civic and since then my temp gauge is ...
Acceleration Bog/Sputter/Hesitation - Honda-Tech
honda-tech.com/honda-accord.../acceleration-bog-sputter-hesitation-279...
Jun 11, 2010 - 1990 Honda Accord Ex F22 209000 miles, recent alternator change When I ... When I take off from a stoplight I get a little hesitation/bogging/sputteringfeeling until about 2,000 RPM then ... My 1999 Accord had a similar problem (F18B2engine). ... It only lasted a second or so before it would actually rev up.
2answers
96 Accord LX, 2.2L. Wouldn't start. Replaced Starter. Replaced Battery. It drives for a little while. Turn it off and it won't start again. Help? Please?
The distributor is a high failure rate item on Hondas if I had to guess I would guess the distributor is the culprit. good luck.
I have an 89 Honda Accord lx and it idles too low
The idle speed for my 88 accord lx is 700-850 rpm for standard idle speed. The stalling is a seperate issue. When were plugs, wires, air/gas filters and distributor last checked? How long has engine been running for when you stall? Is the temprature gauge high? Any lights coming on when stall occurs? I am not a mechanic, but a DYI'er. These are common questions I am always asked when troubleshooting my Honda. :)
2helpful
Stalling
IT COULD BE THE IDLE SPEED SENSOR THAT IS NOT ALLOWING IT TO STAY RUNNING. THIS DEVICE IS LOCATED NEAR THE THROTTLE BODY, WITH A PLUG ON IT WITH THREE WIRES. UNPLUG IT TO SEE IF IT WILL IDLE. IF IT DOES THEN REPLACE IT. HOPE THIS HELPS YOU. PLEASE KEEP ME INFORMED. THANKS FOR USING FIX-YA. AND THANK YOU IN ADVANCED FOR AN HONEST RATING.
1helpful
3answers
I just bought a 91 honda accord se and when you go to stop it stalls or suts off. any ideas of what may be causing this
Check your 91 Accord's ignition coil. The coil goes bad at apprx. 150k miles and cause the car to run rough, hard to start(long cranking time) in the morning, stall after the vehicle has warmed up, cut out while driving and backfire horribly when accelerating from a standstill.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
