HP Pavilion dv4000 PC Notebook
Problem for HP Pavilion dv4000 PC Notebook
Freezing
By kopi on Sep 25, 2006
When I am running two programs at once (ex. internet browser, winamp) almost 3/4 of the times my screen will freeze in about 30 minutes or less. What appears are vertical blue dotted lines across the screen, sometimes the lines are yellow but they're usually blue. The problem isn't overheating, viruses and I know its not a problem about not having enough RAM.
I used a program to check the registry, scan for viruses, deleted programs i don't use and made sure a whole bunch of programs don't run at start up. I'm hoping its not a faulty hardware problem because I don't have the cash to take it to a shop or get a new one, i just bought it and started using it a month ago :(
Same Problem
Dec 16, 2008
-   I have the same problem except my laptop is extremly slow and some of the keys on my keyboard randomly get stuck and i have to press hard on them to get it to read what im typing. and i hate when my cpu crashes and im in the middle of something. im not very computer literate so if someone responds to this please make it understandable to the avg joe:) thanks! -   Guest
Jul 21, 2008
-   Yes, same problem here. No warning or anything. The laptop will freeze up with lines in columns flickering on the screen. Thanks!-   acrick91
Nov 14, 2007
-   ive got a few problems, a few months ago my sound card stopped working. well, actually the microphone works because i can hear my voice on my speakers, and i cant shut the microphone up, it even activates itself as soon as i turn on the power button on my laptop .When it comes to playing any file with sound, it does not play anything, the weird thing is it shows on the media player that the file is playing with sound perfectly, yet i cant hear anything. Im pretty sure its a software problem because i wouldnt be able to hear anything if the sound card was burned or anything, right?. I formatted my hd many times to see if the problem would disappear, I installed many different sound drivers to see if that solves the problem, til i came up with an answer, bought a usb sound card, desinstalled the notebooks sound card, and installed the new one. And now another problem appeared: at first everything was working well, but later on I couldnt play videos on line (on youtube and such) nor regular videos (dvds, avis, mpgs), it only plays five seconds and then it starts freezing, and the it doesnt play at all. Is there really any solution?, or should I just give up? If you could give me a solution I'de apreciate it. bye.-   melvinsucho
Solution #1
posted on Oct 13, 2006
Somewhat Helpful)
sandrew
Rank: Wiz  HP Expert
Rating: 83%, 5934 votes
is it possible for you to use an external monitor, via your rear VGA port and see if you get the same problem, if so its worth checking the drivers for your graphics are current and as daft as it sounds your sound drivers as sometimes they have a conflict and cause graphical problems.
This can be a problem when windows automatically updates itself and sometimes installs generic drivers for graphics and sound and your board doesnt like it.
Hope this is a way forward for you.
Was this helpful?
Yes
No
Solution #2
posted on Sep 16, 2009
Not Rated)
keoulami
Rank: Master
Rating: 83%, 3 votes
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #3
posted on Feb 24, 2008
Not Rated)
tat4u
Rank: Wiz
Rating: 83%, 383 votes
for your;e mic click start,all programs,accessories,entertainment,volume control.
In the next window if you dont see mic settings select properties or advanced .ticking all boxes makes all devices possible.look for the mic and put a tic in the mute box,this doesnt mute it like sound mute it stops its screaming (feedback )through your'e speakers.As for the other probs they are software related(drivers)
you can down load a program called driver genius (free)which will scan your pc for all correct drivers.If you register it ,itll find and install the drivers for you.but as long as you know what drivers you need;you can find and install your'e self
Comments:
Mar 30, 2008
- kopi...the programs youve deleted have deleted shared programs which other programs need to function correctly.
if you need to stop running programs at startup its best to disable them using task manager(ctrl,alt,del)
you may have to now uninstall the programs with problems and then re install them to function properly.
youre probably experiencing fatal exception messages,slow programs response, system freezes and errors.
Mar 30, 2008
- melvinsucho......go to device manager,check vga..display.
if you have more than one driver disable all but the one you currently use.you say u deleted the software but the device is still there and system cant decide which it is to use causing a conflict.another option if system allows is to change resources though this option isnt always available.
also ur usb sound card needs to be connected permanantly or system will revert to last driver.
if you remove ur sound card and check device manager you will notice that it is no longer there until u reinsert it.
I could go in depth about this but hope this enough.
let me know
Was this helpful?
Yes
No
Solution #4
posted on Dec 04, 2007
Not Rated)
wahkao1990
Rank: Apprentice
Rating: 0%, 0 votes
maybe the contact point for the LCD is broken. See when u use it for a long time, the solders expand and break contact and opening the circuit. thus it will freeza up. upon switching off and leaving it for a while, it will cool and the solders will close up again.
yes. one possible to confirm that it is not this case is to connect it to a external LCD monitor and use the computer as per normal. If it freezes, it means ur processor, or ram, or hardware is not good enough.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion dv4000 PC Notebook
Questions and Unsolved Problems for HP Pavilion dv4000 PC Notebook
Do you recommend HP Pavilion dv4000 PC Notebook?
Answer
Answer
When I am using my laptop and I am typing on word, an email or even this very post my cursor moves... (More)
Answer
I was given an HP DV4000 laptop and it will turn on for 5 - 10 seconds (with and without the power... (More)
Answer
how do i restore it i cant see any icons or start
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Pavilion dv4000 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
