Question about Garden
Mcculloch I am trying to replace the spark plug on a mcculloch 16 inch. Standard spark plug fitting from ratchett set will not fit. Appears I have to remove housing to get to plug. Is there an easier way?
  • 76 Answers
They sell a ratchet, thin walled at your local ace/ hardware store, made for chainsaws, actually a thin walled socket w/ holes in end for inserting a screwdriver, take saw w/ you. hope this helps. also it should have two sides one to take the bar off. loosen bolts. other bigger side to remove plug. if you bought the saw new it should have been in the kit.
Posted on Nov 04, 2008
How do I change spark plug in my chainsaw
find where spark plug wire is connected to plug and disconnect very gently, remove spark plug with proper 13/16 or 5/8 wrench or socket and replace with new spark plug
Sep 16, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Replace spark plugs
The OE Autolite plugs installed in the Navigator use a 9/16 inch
socket, which is most exactly the same diameter as the thread area, which makes it look round in the hole. The Champion 7989 uses a 5/8 Spark Plug Socket, which is one of two "standard" plug sizes. The other "standard" plug size is 3/4 inch, which is not used very widely any more.
Nov 09, 2013 | 2006 Lincoln Navigator
I want to fit an 18" bar onto a 16" McCulloch chainsaw
Well, I think it's could be done, but the engine won't be too happy
Mar 24, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where is the spark plug as it needs changsd
  1. Remove air cleaner by unscrewing the knob A
  2. Remove air cleaner cover B
  3. Replace Spark plug
Jun 27, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How doesw one change the spark plug?
1. Push STOP switch down.
2. Remove air cleaner cover.
3. Disconnect the wire connector (G) from the spark plug
(H) by pulling and twisting at the same time (Figure 7-
5A).
4. Remove spark plug with spark plug socket wrench.
DO NOT USE ANY OTHER TOOL.
5. Check electrode gaps with wire feeler gauge and set
gaps to .025" (.635mm) if necessary.
6. Reinstall a new spark plug.
Here is the manuel with pictures as well:
http://pdfservicemanual.com/home-appliance/2006-2008-mcculloch-mcc1435a-mcc1635a-mcc1635ak-mcc1435a-ca-mcc1635a-ca-mcc1635ak-chainsaw-owners-service-manual.pdf
May 03, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What do i check if my saw doesnt start and it has spark
Make sure to use fresh fuel mixed at 40:1ratio. Pour a little fuel mix into the spark plug hole and try for start. If it pops a few times, look for fuel system problems. Check the fuel filter, air cleaner, and muffler for plugging. The carburetor may need internal cleaning and check the condition of the lower chamber diaphragm for flexibility, no holes, or cracks. If the saw if fitted with a primer bulb, make sure that it will fill with fuel when pumped several times. Hope this helps!
Oct 24, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
No spark
if you have tried new plug, remove pull start cover and remove kill wire from ignition coil ( tape wire up so it wont get caught on flywheel ) and refit starer cover - try and start if it starts - faulty ground wire between coil and stop switch or faulty stop switch
but if it does not start or saprk faulty ignition coil indicated
obtain a newignition coil and fit up and set air gap to 0.010 " and tighten the mount screws and refit the stop switch wires and starter cover and let rip
cheers pauly46
Sep 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
