No paper in printer
Message stating no paper although paper is positioned correctly
  • 2 more comments
  • miller8354 Nov 17, 2008
    I keep getting the message :paper out" and printer will not print. Paper tray is loaded with proper paper. I can make a copy, and paper feeds in correctly, and I made a test copy, which was perfect, but cannot make a copy of what's on my computer.
  • RRgroup Nov 27, 2008
    The "paper out" warning light is flashing, but the printer is loaded correctly with paper. I have turned the printer on and off several times, reloaded the paper, rebooted the computer, etc. but the problem remains. Hence, I cannot print.
    If there is a possiblility that there is a small piece of paper jammed inside the printer somewhere, how can I open the printer up to check on that?
  • Louise T Nov 30, 2008
    Ditto, same problem. Any help much appreciated
  • 33carver Dec 08, 2008
    cannot clear hp 7310 out of paper message and won't print - seems to not be able to pickup the sheet!
I have a HP 3210 which worked fine for 6 months then started the out of paper message. I could not get one sheet through it. I tried the HP solutions with no fix. I took it in to a shop and they said it would cost more to fix it than get a new one. I read on a forum that one person said the advance rollers had a slick surface and was not advancing the paper forward. He said he ran 1000 sheets through his printer which roughed up the rollers and he has not had any issues. I decided to try 400 grit silicon (wet dry) sand paper in the tray with the rough side up. I put one in the tray and pulled the back cover and held on to the sand paper for 30 times. Around the 25th time I noticed it was starting to pull harder. That was the trick. I ran 75 blank sheets right after that with out one error.
Posted on Jan 31, 2010
Try using a higher grade/quality of paper. Sounds simple but i experienced the same problem with my HP J6480, and using a better grade of paper cured the problem.
Posted on Feb 18, 2009
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Load 8 1/2 x 11 r
Make sure the paper is set up to the correct size in the paper handeling setup and on the PC you are printing from.
Oct 16, 2009 | Sharp AR-M162 All-In-One Laser Printer
Won't print
The printer is giving that message as the print job sent to the printer is asking for the correct paper type. Check the program you used and its print setup in that program to make sure the correct paper is selected. Software overrides hardware settings on a printer.Another thing is double check the tray position tab and make sure it is set to letter and locked in that position. If the paper tray is not set it can also think that the paper in the tray is a different paper size.
Bruce
Jul 15, 2009 | Dell M5200n Laser Printer
Paper alarm; printer keeps printing same job
remove all supply and then plug then attach data cable, uninstall printer driver and install again
Jun 18, 2009 | Canon MF8180C Color Laser MFC Printer
Paper jam message, but no paper visible
Are there any traces of paper in the printer? Have you tried by restarting printer?
Mar 18, 2009 | Canon PC-D340 All-In-One Laser Printer
Printer
Then you have to release the back side paper jam clear cover and push it back into position. Make sure that the papertray is in good position, too.
Mar 17, 2008 | Brother Multi-Function Center MFC-240C...
Printer won't print
I know that the paper lever is where your paper is loaded. Check the grey plastic tab and try to drag it to the right or left. Depending on your paper size you might have to check the owners manual.
Mar 03, 2008 | Canon BubbleJet i560 InkJet Printer
Printer won't print
hi Printer won't print but the paper come out
Jan 02, 2008 | Canon i 550 InkJet Printer
370 people viewed this question
k24674
jasbo
jasbo
