Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio no audio no video
I have a vu42l, the other night it went out, i called vizio they suggested the inverter boards, i called them back after inspecting those boards which show no sign of heat or damage they informed that the main board controls audio, which also shows no sign of damage, i figured that both audio and went at the same time it might be the power board but the tv does power up (the amber light still turns white when switched on) i hope this gives you enough info, if you can please help because the vizio service center and vizio has been little help, by th way the set was 20 days out of warranty
  • 4 more comments
  • wunder-shon Nov 02, 2008
    that was the first thing i did now have it apart thry find the bad part
    that was the first thing i did with same result
    i left it unplugged for 8 hours when it first happened, then tried again after 48 hrs, with same results
  • wunder-shon Nov 03, 2008
    does anyone have any other ideas on this vizio
    where are these condesers located on the corners of what
  • wunder-shon Nov 04, 2008
    i have been thinking te same thing i have been checking the samsung 8 and 9 series and also the sony xbr 5 series any suggestions
  • 1,512 Answers
Hi, in the interests of you getting your problem sorted out, I suggest you phone back Visio customer service, NOT there agent, but the actual head office/distributor for the set, ask for the service manager, and use notes you have prewritten for yourself to tell him how many ways you are dissatisfied with the set and the number of workmates, friends and family that you are going to tell not to ever buy on of those sets. If you make enough fuss in this manner, the common result you will get is for them to advices you to take it to one of their approved agents, and they may well fix it for you under warranty. I have worked as a service manager for more than 16 years, and if you go about it in a non aggressive manner, they will do what you want in the interests of customer satisfaction. It is what most all the majors will do for you at least. Try it. Let me know how you get on.
regards
robotek
Posted on Nov 04, 2008
  • 728 Answers
You might have a short in the power board that puts the tv in stand-by mode to stop it from catching fire. You will need to get it reset by a trained professional and to get it checked for any other things that may have caused the short. Try using the aux option and see if that gives you any picture or sound. The tv has a small on-board battery to remember time and other stuff. Try doing a full reset by unplugging the power and cable cords and let it sit overnight and then try it. If the problem persists, you will need a professional to come check it out and to get it fixed.
Posted on Nov 03, 2008
    Top Expert:
  • Vizio Master
  • 63,312 Answers
All the above tests and poss problems are most likely good remote diagnose, but only so much can be done from a key board, a hoard of test gear and tech manuals is required to fix these modern big screens, when all is said and done this model now sells for less than $900, you will most likely have $500 mor $600 in it when the repairs are done, why? because they don't fix individual parts on circuit boards anymore, they replace the whole board, most are $300-$400, then allot of labor. Do yourself a favor and scrap this TV and just buy a new one.
    Genius:
  • 2,920 Answers
There are 4 condensors in each corner if any of them are popped up there will be the peoblem.they are supposed to be flat on top not rounded
    Master:
  • 505 Answers
The TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
As already pointed by the other expert, from description, the digital processing board. can be cause for the problem as there is no video.
However all the following parts can be involved.
Parts involved can be
Polaroid digital processing board.
Polaroid replacement ballast.
Polaroid Replacement LCD controller
Thanks
Posted on Nov 02, 2008
  • Vizio Master
  • 19,396 Answers
Try first unplugging power cable for ten minutes, see if this can reset the unit.
  • Ginko
    Ginko Nov 02, 2008
    Hi there, sorry I was away.
    If there is also no sound, then the inverter board has nothing to do , an inverter board fault affects only display and video.
    No body not even a technician can tell you what is wrong from here with the TV without testing it, unless an error code is displayed.
    I understood that you loss both audio and video at the same time, and the TV went in standby mode.
    Possible faults are:
    Power board: this is the first thing to check, it is not true that if the power board is faulty the TV won't start at all.
    If one of the capacitors on power board is faulty the TV will probably start and stay in protect mode (standby).
    Sustain cards (Ysus etc.) this are easy to test, by removing one by one the sustain cards and starting the TV for few seconds, if the sustain card was faulty the TV will start regularly. TV must not be left on for more than few seconds without sustain card.
    Main board: that is more difficult to troubleshoot, you need necessarily to follow troubleshooting diagrams on service manual.
    Short or fault on other boards (sound, signal board, controls etc.): this also requires testing the board components, even if boards are smaller than main pcb, always better having service manual.
    The whole thing is not easy job as it can look, if you do not have experience in fixing electronics, and as the warranty is just expired, you can call factory and ask a for warranty extension.
    You will be charged a fee that is surely inferior to the cost of repair, and will cover your product for one extra year.
    To call manufacturer you can use the phone number listed on the owner manual.
Tv picture problems on Vizio m3d460sr hdtv lcd (back lighting out ?)
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 09, 2014 | Vizio M3d460sr 46 Black 1080p Tv Lcd
Vizio VU412L 42" made a
The pop has been generated by the explosion (literally) of an capacitor from the power board of the tv. When that happened the power source has been shorted and, if you're lucky, it went in protected mode. Fixing that is a relatively simple job - all you need is a soldering iron and a basic experience in using it. Follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
If you're unlucky the entire source has been fried and it will have to be replaced - here's a good one
http://cgi.ebay.com/VIZIO-VU42L-FHDTV10A-POWER-SUPPLY-DPS-283BP-C-REV-S0-F-/370477438027
Mar 06, 2011 | Vizio VU42L 42 in. LCD TV
My Screen Went Black and i can only hear Audio.
Ur tv the LCD inverter board it dead.This board it help to get a backlight to ur LCD screen panel go through the Tuner board to produre a picture.Replaced this LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 26, 2010 | Sanyo 42 in. LCD TV
No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
Jun 18, 2009 | Vizio VU42L 42 in. LCD TV
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Mar 26, 2009 | Vizio VU42L 42 in. LCD TV
Vizio P2 42 in. HD-Ready Plasma Television Logo
49 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
