Question about Dryers
I need a schematic for a hotpoint Model#DLB155ORALWH dryer to fix a heating element problem
    Sergeant:
    Champion:
  • 324 Answers
What problem are you having?
Posted on Nov 03, 2008
Can I twist back together the heating elements after they break? I have a Hotpoint model # nvlr333ev0ww
Not sure you want to do that....not totally familiar with that machine, but anytime you force pieces back together you can get a short and cause a fire. Here is a part list for your model and schematics for the assembly might help. http://www.searspartsdirect.com/hotpoint-dryer-parts/model-NVLR333EV0WW/1811/0151200/G8080005/00004.html
Sep 02, 2015 | Hotpoint Dryers
Hwant schematic for Maytag dryer model YMEDE301YGO
Go to Partselect.com. they will ask for model number and serial number of your dryer. They have every single little part for appliances but better yet they have video's on how to make the repairs. They also have schematics for every conceivable appliance made. the prices are very reasonable and the customer service is top notch!
Mar 05, 2015 | Maytag Dryers
Ariston AS66VXNA dryer - everything works but no heat- looking for a schematic to check out and troubleshoot - where can I get detailed schematic?
You can find a manual for your model here>>>>>>>>> http://laundry.manualsonline.com/manuals/mfg/ariston/asl70c_1.html Let me ad that you may have just one side of the 240 volt circuit breaker or fuse set tripped or blown allowing all of the electronic functions, but not allowing the full 240 volts across the heating element. One way is to check the fuse box first and then proceed to measure voltage across the heating element after turning on the dryer. Please use caution while doing this. Ariston Clothes Dryer User Manual ManualsOnline com
Jan 17, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
I am looking to replace the heating element on an old hotpoint electric dryer and cannot locate how to find it.
Depends when the dryer was made, older models had the element at the front behind the front panel.
More recent models all have the element located at the rear of the dryer..
Hope this helps.
Dec 29, 2009 | Hotpoint Dryers
Model NVLR333EVOWW Not heating up
your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Dave
Jul 22, 2009 | Hotpoint NVL333EY Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Hotpoint electric dryer model nvl333eb4cc not dryer clothes. where and how to check for the heating elements or any component that might be at fault
1. Reset a circuit breaker
2. To check the component you have to lift the top of the dryer.
3. all heating component located on the back of the drum.
4. The problem could be one of the safety thermostats or heating element.
5. To replace a heating element is to complicated if you do not have experience.
6. let me know if you going to do this
Nov 29, 2008 | Hotpoint Dryers
Not heating up
This looks like it is an older model. The normal place I check for parts doesn't stock the heating element. I found an alternative place but the part is $90.
The element is in the large round area that surrounds the drum assembly. Here's a diagram. The heating element is part number 512. The line doesn't reach all the way there but I think the element is the two dark rings inside the housing. Here the page with the parts listing. You'll note that the model number is the same but the brand is GE. GE makes hotpoint.
Sep 25, 2008 | Roper REX4634KQ Electric Dryer
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
106 people viewed this question
Top Dryers Experts
