Question about Sanyo PLC-SW30 Multimedia Projector
Sanyo plc sw30 help
I have a sanyo plc sw30 went to put it on the other night to watch film and when i powered it up after about 5 seconds it went straight to cooldown and back into standby anybody help me.........
  • mickusbandit Nov 02, 2008
    hi blakey
    thanks for your help will try to see if i can get a bulb just a pain in the *** only used it three times since i got it off a guy on ebay...
    anyway thanks for help
I had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Posted on Nov 02, 2008
Sanyo plc-sw30 i have a problem when i power on the projector , there is no power lamp on a very slow light is visible and the projector shut down and the fan are in very high power
The uProcessor thinks that it has overheated and is frantically trying to cool down what it thinks is a hot lamp.
This condition has many causes from an exhausted lamp to lamp ballast fault or even a power supply fault or a heat sensor/fan fault.
Mar 30, 2011 | Sanyo PLC-SW30 Multimedia Projector
How to fix shadow (stain) projected onto screen by projector Sanyo PLC-SW30
This could be showing the signs of the lamp needing replacement. if not dust has accumulated (clean filters) onto the mirrors in the projector.
May 15, 2010 | Sanyo PLC-SW30 Multimedia Projector
PLC-SW30 Multimedia Projector no power
You have a classic temp sensor problem. Its a fail safe on the projector, basically a fuse that bridges the main power cables. Looks like a little pot, With a white ceramic head.
Now what it does, Is the white ceramic head rises as the unit gets hotter, and thus breaks the power circut. All you need to do is, open up the unit, locate the sensor (its mounted next to the lamp on your projector) And push the little white head back down, thus closing the circut, and restoring power supply.
Here is the full repair schematic to guide you. :)
http://yama.co.za/forum/index.php?topic=146.0
Aug 01, 2009 | Sanyo PLC-SW30 Multimedia Projector
Projector turns off after 5 seconds
You have a classic temp sensor problem. Its a fail safe on theprojector, basically a fuse that bridges the main power cables. Lookslike a little pot, With a white ceramic head.
Now what it does, Is the white ceramic head rises as the unit getshotter, and thus breaks the power circut. All you need to do is, openup the unit, locate the sensor (its mounted next to the lamp on yourprojector) And push the little white head back down, thus closing thecircut, and restoring power supply.
Jul 12, 2009 | Sanyo PLC-SW30 Multimedia Projector
Opening a Sanyo PLC SW35 projector
Hi There, Ive recently repaired my sanyo plc-sw30/35, Had many issues. Ive made the ful schematic available on my site http://www.entwan.netau.net/1_8_Repair-Schematics.html
This should help you.
Apr 20, 2009 | Sanyo PLC-SW35 Multimedia Projector
Sanyo PLC-SW30 Multimedia... Problem
sanyo_plc_sw30_multimedia_problem i need support
Feb 27, 2008 | Sanyo PLC-SW30 Multimedia Projector
Configuration
hello Friend
Connect the RGB Cable of the laptop. Power up the Projector and restart your Laptop. that will automatically run. Or Go to laptop display properties by right clicking the mouse and settings to resolution 800x600 pixels and then check.
Viren
Rave Services India
Feb 07, 2008 | Sanyo PLC-SW30 Multimedia Projector
No powers ups
does the lamp try to fire up
check lamphouse and fan filter safety switches
Jan 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-SW30 Multimedia Projector Logo
311 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
