Question about Zanussi 24 in. DE6744S Free-standing Dishwasher
Stopped Working Hi, My Zanussi Aquapulse Dishwasher (DE6744S)has just stopped working. The red on/off switch still lights up when I try to start off a wash but nothing else happens. I know this is probably just a case of "call out a repair guy" but, even though I've had the machine a few years, I'm I bit miffed on the thought of coughing-up to have the thing repaired because I very rarely use it. Any suggestions? Many thanks
  • Anonymous Nov 07, 2007
    This is exactly the same problem that has just happened to my dishwasher. The manual said make sure the door was shut properly. Checked that, still not working.
  • Anonymous Dec 04, 2007
    Any ideas what to do? We have the same problem.
    WE have tried to get a new door closed switch - will let you know if it works!
    Problem Solver:
  • 18 Answers
The problem is with the PCB, this is the board behind the buttons, you can buy this for £120 or you can get it fixed by QEA for about £45 link below. I am not an engineer but I replaced mine in 10 minutes.
http://www.qualityelectronicrepairs.co.uk/lists/laundrymodels-zanussi_1.html
Posted on Aug 03, 2010
CALL OUT A REPAIR GUY
Posted on Feb 13, 2008
My Zanussi aquapulse de 6654 will not start. Only the on/off switch light lights.
Hi, I have a zanussi de6965 had the same problem the only indicator light that works is the on-off button.I had a problem some years ago with my machine would not work and showed L3 as the fault as I remember. I was advised to switch off all power isolate from the wall is best(pull the plug out of the socket) I removed the front casing held along the top and down the inside by a number of small screws. You need to leave the two bottom screws in(one each side) Wiggle free the top half of the display panel to acess the box holding the PCB board.it's very fiddly you will need a sheet of paper and a pen to make a noet of the connecting sequence of the wires ( Mark the blocks of wires with numbers... when replacing everthing this should eliminate any problems) Remove the PCB board from its casing and turn over to expose the back. At the bottom left hand side I discovered two dry joints, I needed a magnifing glass to check all the joints just incase. The faulty joints were a little discoloured blackened slightly. Solution...I cleaned, fluxed and re-soldered the joints. When re-assembled all the parts. It will help when dismantling to keep a note of the number and size of the screws and where they were removed from.
My dishwasher is now working again. hope this helps.
Sep 23, 2011 | Zanussi 24 in. DE6965 Built-in Dishwasher
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
Water not heating up
There is a small round solinoid that might have blown its just under the element, you could try this, it cheaper option.
Jun 28, 2010 | Zanussi 24 in. DE6744S Free-standing...
My zanussi zwx1605w was washing then just stopped working.
zanussi zwx1605w. i have lost my manuel and cant washing machine to start?
Mar 26, 2010 | Zanussi ZWF1650W Front Load Washer
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
Dishwasher zanussi aquapulse
this sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Sep 19, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
821 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
