Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
My 775 will send but will not receive faxes.
Machine faxes fine but will not receive. Are my settings off??? thx, MT
  • fjbeyo Nov 10, 2008
    Mine will ring half a ring on incoming, then disconnect. Have tried set to FAX only, and Tel/FAX.
  • 318 Answers
It can be.Do you use it as a fax only?Tel fax?
Posted on Nov 03, 2008
Help with Sharp Fax UXP100 . When sending a fax they are going very, very slow. What should I troubleshoot? Thx
Check your phone line by removing fax and plugging a normal handset into the line socket and then listen to line. If a line has noise on it, it will slow transmission down, it can also cause wiggly lines on transmitt and receive, if this is the case, it needs to be dealt with by your phone line provider, just report a noisy line
Having the machine set to fine in transmission settings can also cause slow faxs, and a dirty scanner glass can also cause receiver image to have marks on received image but it is normally marks down the page
hope my good deed free for the day helps.
Nov 22, 2011 | Sharp Office Equipment & Supplies
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Magic Jack quit transmitting, but receives on Brother 775 fax
wheneva i start ma magic jack it say connect to internet an put password its says correct but thn again its comes again connect to internert.... an password an email id... but pls help me in tis..??
Jan 07, 2010 | Lands Phones
Not pausing to acknowledge
Open up the feeder to see if a piece of paper is holding a switch actuator down.
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Can send but cannot receive fax
check it is in fax mode in setting ------try to clean with air blower and soft cloths------check inside for any foreign object droped inside(pins--stapler-any small pieces of torn paper.------check microswitches in paper path for broken lever and test it with your hand and feel free moving.
Apr 28, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Aug 21, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
James Cagle
James Cagle
Jim Keysor
