Question about Apple iPod nano
Ipod nano i connected my ipod nano to my computer into the usb port and it says that the device is not recognised. i went through the device manager from the troubleshooter and all it says is unknown device and there is nothing i can seem to do to fix this problem please fix this problem for me. melissa
  • 3 Answers
Try deleteing everything on it before you plug it in, it could just mean there is a corrupt file on your ipod that the computer cant read.
Posted on Nov 02, 2008
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
New iPod Nano 4G won't connect to iTunes.
Hi Paige,
  • First reset the device by pressing and holding Menu & Select till the apple symbol appears
  • Next check the USB port on both the PC and ipod are clear of dust etc.
  • Download and install the latest iTunes from the Apple site.
  • Connect the ipod to a USB port directly on the back of your PC (ie, not a USB hub or keyboard etc.)
  • If iTunes recognises it (properly or improperly) and suggests an ipod software update, do this.
  • On the main ipod page of iTunes press the restore button and choose the bottom option (if it gives you any) to restore the ipod to manufacturers settings.
  • After a couple of restarts once its done it should be fine.
All the best
Sean
PiDigital
Dec 25, 2008 | Apple iPod nano
Ipod nano 4gb
When i open my Apple IPod, screen turns to initiation mode and does not open. My PC also does not recognise the USB devise. Kindly help.
Regds,
Rafi
Jun 06, 2008 | Apple iPod nano 3rd Generation
HELP!!!
What OS do you have?
May 19, 2008 | Apple iPod nano
HELP!!!
Try a different USB port if you have one.
May 12, 2008 | Apple iPod nano
Ipod
· go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
· Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Jan 07, 2008 | Apple iPod nano
Registering & Syncing Ipod Nano 3G
try reformatting the ipod. that might reset it.
Dec 20, 2007 | Apple iPod nano 3rd Generation
Switching on problem with I pod
Restart your ipod (hold the middle button, menu button, and play button for about 10 seconds). That will restart your ipod, and should make it work.
If that doesn't work, follow the instructions on iTunes to restore your ipod to the original factory settings.
Oct 16, 2007 | Apple iPod nano 2nd Generation MP3 Player
İpod nano not seen at explorer and itunes
- check the cable - check the connections on the bottom of the ipod for bent pins, or dirt - make sure ipod battery is fully charged - if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though. - check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager) - uninstall usb ports on pc, let pc redetect them
Aug 25, 2007 | Apple iPod nano
Apple iPod nano Logo
78 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
