Question about Akai PT5492S 54" Rear Projection Television
Power and front control box not working
I cannot turn my tv on or off, the power buttons on the front panel are not working at all, no volume control nothing at all. My remote is not responding to the tv either....I have left the tv on and am currently having to turn off the cable box only which is blacking out the screen where it looks off but the power is still on..... Any suggestion on how to fix? Thanks
  • 3 more comments
  • ROXYZ1227 Nov 05, 2008
    I want to say thank you for the advice on the hard boot "IT WORKED", so thank you again for taking the time out to respond you saved me the cost of a new tv.
    Thanks again.....
    Roxy
  • sroberts56 Nov 05, 2008
    My tv will not power off from the front or the remote.Otherwise it is fine When I turn it off it will come right back on only with no sound remote will not restore sound have to turn off again and sound will restore when it comes back on second time
  • jamerson82 Dec 03, 2008
    l plug my tv in but it will not turn on or off when l plug it in l here two click sounds like it is coming on and none of my controls are woking at all two.
  • tatman320 Jan 20, 2009
    can you tell me what you did to fix the problem? my control panel is doing the same thing ( nothing ) have to turn off the cable box so the set is still on,, what is a hard boot,, that is what you said worked,,
    thanks,, Brian
  • sroberts56 May 11, 2010
    Tried this did not work on my set. Any other suggestions Thanks Sherry
  • 934 Answers
Try a har reset, by unplugging the Tv for about 5 minutes then plug it back in and see if the remote functions are restored..
Bill
Posted on Nov 02, 2008
  • William Rayburn
    William Rayburn Nov 06, 2008
    Roxy,
    Thank you for a final comment and letting me know how things turned out. It is rare that techs such as myself get that opportunity especially those like me who are donating their time and efforts just to help and don't know if we're actually making a difference.
    Bill
    William Rayburn, CET
    Premium Technologies
    PO Box 442
    Long Beach, WA. 98631
    360-642-4993
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have an Apex televsion, model no. AT3208S. My remote control buttons are not working correctly...nor are the buttons on the front panel of my TV. I can turn up the volume but can not turn down the...
IT is not available in the elect market,soyou connect one set topbox through audio/video input socket then you can change with the help of set top box remote.
Aug 02, 2010 | Daewoo Televison & Video
Volume control not working
Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Front buttons on TV no longer work or thr remote control
Double check the wire plugs from where they connect to the front keyboard panel and the main chassis
Jun 18, 2009 | Toshiba TP61G90 61" Rear Projection...
Front panel buttons on Philips rear projection do random things
Leaky tact switches on control panel. Part number is 242212802742. Takes 6. They will cost you around 6.00 a piece. Lower front panel pulls off. Be careful as there are two cables attached to htis panel. This should take care of your issues.
Pete....Digital TV & Radio in NC
May 16, 2009 | Philips 55PP9401 55" Rear Projection...
Controls
the sensor for remote has fallen off its usually connected to a 8 inch wire which fell back into system pull the sensor wire forward the way to get into tv 3 ways front pannel pops off sensor is set at front
there the back of tv
then theres threw the
Mar 19, 2008 | Apex Digital GB5108 51" Rear Projection...
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Akai PT5492S 54" Rear Projection Television Logo
114 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
