Question about Krups ProAroma 453-71 Coffee Maker
Krups proAroma- Everthing appears to work except it won't brew??
The Unit is listed as a Krups ProAroma -Type 483 12 cup programable
coffee maker- One day it just stop brewing, the operating light went from
green to red- the clock runs, program clicks But No Brew
Please help .
4 Suggested Answers
  • 4 Answers
SOURCE: My Krups won't brew
The culprit is probably the thermal fuse. It's under the bottom cover, and you have to have Torx security bits (the ones with the holes in the middle) to remove the three screws holding it in place. Sadly, the thermal fuse is not resettable. Once it's tripped, it's dead. If you have this problem, forget about getting Krups or their lame service agent, smallappliance.com, to repair it. Both contacts I had with Krups were unsatisfactory. The factory/customer service folks say that there are no parts available and to buy a new coffee pot. Great solution. You can damn well believe it won't be a Krups. Or is it ****? An otherwise perfectly functioning unit gets sent to the landfill because the folks at Krups can't be troubled to find the part number. Idiots. For your info, there are thermal interrupters made by several manufacturers. The trip temperature on the breaker is 318 degrees, C. Something in the neighborhood of 200 degrees C would probably work, but would have to be soldered in. If you are comfortable with doing that, it's a solution.
Posted on Apr 17, 2008
SOURCE: Braun Proaroma coffe pot wouldn't brew
I found on online operater's manual for this coffee pot and solved the problem.
Posted on Aug 22, 2008
had the same type of problem with a hair dryer once. A thermal interrupter- I called it a planned obsolescence gizmo- died. I bypassed it with a silver wire soldered in and the hair dryer ran well until another part died years later!! Sailorb
Posted on Sep 14, 2008
I need to replace my Krups 453 Thermo fuse (ms-0061607). Where can I find one or is there a replacement?
Many times the Thermal (not Thermo) fuse is soldered in line with silver solder and unless you have the ability to cut the old one out and replace it, the cost would be greater than a replacement coffee maker.
Jan 05, 2015 | Krups ProAroma 453-71 Coffee Maker
Our Krups heats the water but does not brew
may be its not heating properly try some descaleing
Jul 13, 2014 | Krups ProAroma 453-71 Coffee Maker
The Krups coffee maker brewed as usual, it was a little hot so I did a few other things went back to the coffee maker it had shut off by it's self and now wont come back on???
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Oct 31, 2010 | Krups ProAroma 453-71 Coffee Maker
The coffeemaker tube leaks on my Krups ProAroma 452. How do I replace the tube?
I have the same problem. The rubber elbow seems to have shrunk with aging. Krups customer service pointed my to SmallAppliance.com for a replacement part. It appears that "Krups 0067516 Coffeemaker Tube" is the proper replacement. It is a special order part that may take 6 weeks to ship. The elbow pulled off a connection inside the coffee maker and I hope that the replacement will just slip back on. While I haven't completed the repair, I think I'm on the right path.
Jun 17, 2010 | Krups ProAroma 453-42 Coffee Maker
I lost my user manual for a Krups ProAroma453-71 coffee maker. Where can I find one?
Contact Krups, and they should be able to send you out a new one. Their phone number (according to their website, www.krupsusa.com ) is 1-800-526-5377
Good luck! :)
Aug 26, 2009 | Krups ProAroma 453-71 Coffee Maker
How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Jun 05, 2009 | Krups ProAroma 453-71 Coffee Maker
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Krups ProAroma Type 314
Thermal fuse gets stuck, gently take it apart and reverse the thermal button over, clean the rust under the button
Oct 07, 2007 | Krups ProAroma 453-71 Coffee Maker
Half a pot short of a good morning
Sounds like the thermal fuse (search this database under "fuse" and you'll find a discussion of it). I have yet to find the proper TORX security wrench, so I haven't been able to get to mine in order to try the things mentioned there, but I have a similar problem and what is said there makes sense.
Aug 18, 2007 | Krups ProAroma 453-71 Coffee Maker
Krups ProAroma 453-71 Coffee Maker Logo
110 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
