Question about Acer Computers & Internet
My acer al 1923 computer monitor will not turn on.. sometimes when i plug it in it turns on and when i press the off/on button it turns off but will not turn back on.. what is wrong?
Acer monitor: this is a common problem. Most of the time it is an powersupply fault. If you are tecnical and not afraid to soldeer,is it easy to repair. you have to change the condesators in the power supply. change C244,C263 (470uf/25V)and C241/C261 (1000uf/10v) you can find them on the supply board. Most of the time, you can see that they are bold on the top . The parts wont cost more then aprox. 4 euro's My advise is to change all four of them, even when they aren't broken, because you'll have the most work with taking the monitor apart. Try to keep the alu. stickers at one piece and watch the polarite from the condesators carefully ! succes! Jan.
Posted on Mar 26, 2010
My ACER AL 1717 monitor.The on/off button is flashing green, but the monitor is not turning on. I have checked all the connections...help! It blinks even if the connection from CPU is not given to it.
It sounds like you may have bad capacitors on the power circuit board inside your monitor.If you are willing to try a repair yourself,let me know,i can try guide you :)
Jul 05, 2015 | Acer Computers & Internet
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
When I turn on my monitor which has been plugged into my laptop; the Acer name shows on the screen and then it fades and the message shows "no signal" and then the light on the power switch goes red. I...
Try pressing the AutoSet button and if this fails try a different cable. Make sure that you press the external monitor select key on the laptop and that the brightness and contrast is not turned all the way down.
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
GETTING A NO SIGNAL MESSAGE FROM MONITOR
Hey,
Press a few buttons on the keyboard incase the computer is in sleep mode.
If you still don't get picture at all, the issue is with the computer, please test the screen on another computer to see if the problem persist there, if it works perfectly on the other computer then theres a problem on the computer and I suggest you get someone to look at it.
Thanks,
Ekse
Feb 15, 2009 | Acer AL2216WBD LCD Monitor
ACER AL 1716
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Oct 11, 2008 | Acer AL1716 F Monitor
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
Computers & Internet Logo
383 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
