Question about Frigidaire Refrigerators
The freezer works just fine, the food/milk compartment is room temperature, even though the control is at 5. Can I fix this myself?
  • 59 Answers
Open the freezer door and listen. If you can't hear a fan running inside the compartment then you probably need a new evaporator fan. If you can here it check for excess frost on the rear panel inside the freezer section. If there is frost there then you have a defrost problem. If there is no excess frost then you should check the damper at the top or the fresh food section. Let me know if you need more info. Good Luck!
Posted on Nov 02, 2008
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Feb 19, 2010 | Refrigerators
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
Have Sub zero side by side 561 Why does the temperature control not increase the cooling of the refrigerator? The milk and vegetables are spoiling.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Refrigerators
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
The freezer stops working when the room temp drops below 60
Refrigerator operation is controlled by the internal temperature . When there is very little ambient heat available to leak in to cause it to cycle more frequently and there is no door traffic to be a heat source the freezer temperature will increase. Keep the room heated to a higher temperature or remove frozen products is the answer. A small chest type freezer will keep food frozen while you are away and have the heat turned down.
Nov 11, 2008 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
