Question about Ricoh Aficio CL3500N Laser Printer
What to do about fading down center
Having blank (fading) areas down the middle of the page (top to bottom)
  • kferraro Nov 17, 2008
    I am pretty sure that you will have to replace the black photoconductor. Search for Ricoh type 165 photoconductor. They run about $130. What ever is electrical that is holding the toner in the center of the unit has failed. FWIIW, I have had to replace quite a few of these, some under warranty and some not on the six printers I support.
  • Ricoh Master
  • 691 Answers
Start by cleaning the laser glass. This may well clear the issue. See if you can see toner spillage somewhere that could be preventing the laser drawing the image. Also check the fuser for a plough line .
Posted on Nov 09, 2008
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Hi, I have DataMax ST3210, while printing it is instering a blank page randomly. Please advise
Check that your format is centered top and bottom on the stock, and that you have at least 1/8" quiet area top and bottom.
If you are printing on stock with an eye-mark, ensure that your print does not interfere with the area at the eye-mark. The printer will try to print the format, but if the eye-mark is in the way, even if the format is printed completely, will feed a blank label.
The also applys to standard die cut labels. with standard 1/8 die cut between labels
Nov 10, 2010 | Datamax DMX-ST-3210 Printer
Light swath of printing down middle of page..
This is due to Black developer , Kindly approach authorised service center to get it changed.
Best Regards
Mar 01, 2010 | Samsung CLX 3160fn All-In-One Printer
Fading down the middle
Lower then remove rear door.
Lift the two blue tabs , remove the fuser and inspect the top roller
Jan 29, 2009 | HP LaserJet 4250n Printer
HP3600N color fade
It is using the colours to make the grey and the proportion is not correct. Do a calibration.
Dec 23, 2008 | HP LaserJet 3600n Printer
Samsung clx-3160fn
This is usually due to the imaging unit going out, but can also be a problem with the main board itself...unfortunately that means rma is really the only option...which is NOT going to be fun fyi as samsung has poor customer service.
Aug 30, 2008 | Samsung CLX 3160fn All-In-One Printer
"Skip Blank Page" Set to 0.1% Yet still skips pages with footers and headers
We have the same problem where I work. We use a black texta and draw a line down the middle of the page. This gives the scanner a point to pick up apart from the minimal text at the top. However, this will only work if you are happy to have a line on your scanned document!
Apr 09, 2008 | Canon DR-9080C Path-Through Scanner
Faxes only top of page center is blank
change your resolution from fine to super fine and make a copy to verify your fax machine"s scanner operation.
Mar 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
310 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
