Coleman direct vent forced air gas furnace and asthma
Does anyone know if type of heater can make asthma worse? Every time we use it I have awful coughing and shortness of breathe. Is there anything that can be done to stop the problem?
  • Janet Geren
    Janet Geren Nov 03, 2008
    Thanks. I actually have an air filter with a uv light, but as soon as the heater goes on my coughing is spastic. We even put filters on the ducts. I am not sure where to get a uv light or how to install, but I suppose we can find out at a hardware store. Thanks again.
  • haikieu Oct 09, 2012
    Thanks. I actually look for the transformer detailed *** follow-mentioned :"Transformer ESSEX 591-406800-10001-2940-354 PRI 120V 50/60 HZ 1/4QC - 1/4QC SEC 24V 40VA 1/4QC-1/4QC Class2- For Coleman Model 2735-666 Gas Forced Air Furnaces" .Could you help me? Thanks a lot !!!!
    Problem Solver:
  • 22 Answers
Maybe try a UV light on the duct work, my son has same problem and i installed a UV light and the house smelt better and my son could breath better.
Posted on Nov 03, 2008
I have a coleman 7956c856 direct vent forced air furnace it ignites fine but the blower wont kick on
main fan should come on once furnace has heated up to supply hot air to the house. make sure proper voltage going to the fan. fan relay in board may be shot
Jan 29, 2014 | Goodman GMS90703BXA Heater
I have a gas furnace model # 2sg13b36090p-1a green light flashing 2 times slow
Hello, Maybe this will help you some.
I hope it does, Mike
Oct 26, 2011 | Coleman Propane Forced Air Heater...
My Coleman direct vent forced air furnace 7995-656/D will fire up but the auto fan does not come on. I can cheat this by cutting the fan to on after the burner heats up. Whats my problem?
two things the pressure switch not working or the fan control afc not working could need cleaning at the back of the afc try this the afc works on temp rise to bring on the fan afc temp fall to shut of fan so it sound like the afc is not coming on at temp rise, also check if air filter is clean
Jan 19, 2011 | Coleman Propane Forced Air Heater...
I have a Miller furnace with central air. I am looking to change to a propane gas heater. Looking for cost of Coleman furnace, or can a miller oil furnace be changed to a gas furnace?
Yes it can do but you will be better off by gone to a gas heater. MY own furnace was chance over to propane and didn't workout to good. Less then ayear i have put in a new heater. Ken's Repair
Jan 18, 2011 | Coleman Propane Forced Air Heater...
It should have a two part chimmney with a 4 inch inner exhaust section and a larger 6 inch outer section that goes over the flange on the top of the furnace. If your existing chimmney does not have this you may have to buy a chimmney kit for a mobile home application.
Dec 11, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Furnace clicks multipal times while running.Is this normal?
As it starts and stops several switches will open and/or close, sometimes you can hear them. When it's just running then it may make a few noises from expansion and/or contraction.
Mar 30, 2009 | Coleman Heating & Cooling
How to wire a Coleman proprane furnace
I just bought a houseboat with the same furnace in it.  I will check it this weekend and provide you with the wiring directions should you still need them.
Mar 07, 2009 | Coleman Propane Forced Air Heater...
Heater flashes 3 times says it means combustion switch failed to close
Combustion switch is your vent safety.. Check your vents outside for blockage, sometimes the intake pipe will freeze or frost up not allowing the preassure switch(vent safety)to close. putting furnace into a lock out.. you can reset the furnace by turning the power on and off.. if there is no power switch just remove the bottom door and reinstall...
Jan 08, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
387 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
