Home | Toshiba | 43H71 43 in. Rear Projection Television | Vertical Red/Green lines
Toshiba 43H71 43 in. Rear Projection Television
Problem for Toshiba 43H71 43 in. Rear Projection Television
By uber33t on Sep 25, 2006
After my 43H71 is on for about 30 minutes, red and green lines begin to appear at 1/3 and 2/3 on the screen. At first, it's just a few pixels along these lines. As time goes by, more and more dots appear along these lines until they are almost solid (about after an hour of the TV being on).
I've done the touch focus auto convergance, but I don't know what else I can do.
I just recently move the TV across the city, and the problem was not present before the move. (We were careful, and didn't hit any big bumps or anything....)
Best Solution
posted on Sep 25, 2006
Very Helpful)
bunkermaster
Rank: Master
Rating: 89%, 22 votes
I agree W/Techman sounds like the convergence amps are goeing bad
if you do change them upgrade to stk392-180 for the stk392-110
they will last longer good luck Walter Grzybowski
Was this helpful?
Yes
No
Solution #2
Not Rated)
techman
Rank: Guru  Toshiba Expert
Rating: 86%, 7605 votes
You have bad connections on the board and need to be resoldered or the convergence IC's are bad. If you know how to solder on solid state elctronics then you can change the IC's or find a bad connection on the board if you know the High Voltage issues when working on a TV set. If you have to training on TV sets I highly recommend that you call a service person to assist you in this repair.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 43H71 43 in. Rear
Questions and Unsolved Problems for Toshiba 43H71 43 in. Rear
Do you recommend Toshiba 43H71 43 in. Rear Projection Television?
Answer
Answer
the picture is messed up- the colors are separate and shadow-like.
Answer
tv will turn on but have no picture. the power light does not flash just stays constant
Answer
Toshiba flat panel model #PDP42X3 shows no picture but has static sound is it fuses? How do I know... (More)
Answer
toshiba tp61f90 no picture when i hook up cable to either tv video 1 or 2 standard cable jack. if i... (More)
Answer
Good sound but picture goes after a short time, half hour to about one hour. But now there is no... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 43H71 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
