Question about Philips Magnavox 55P9271 55" Rear Projection Television
1993 46 inch Magnavox no picture
It just happened this morning turned the TV on and have no picture only sound. Can change channels and the sound changes tried VCR for input and same result. there are no lines or anything on the screen it is just black.
    Genius:
  • 1,139 Answers
Hello All,
I posted this earlier, however I believe it applies in this case to:
This can be any number of things, here is a possible listing:
1) No High Voltage (check the IHVT or the trippler)
2) CRT filament transformer winding open (check the windings that supply voltage to the CRT filaments)
3) Video / CRT socket boards bad (highly unlikely but check anyway)
4) High Voltage power supply malfunctioning (related to problem #1)
This listing is a good starting point. I would suggest that you purchase a schematic to aid in testing the voltages mentioned in the 4 steps above. If you have a background in electronics then do the above, if not please ask a qualified TV technician to perform these steps.
Thank you,
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Dec 27, 2014 | Magnavox Televison & Video
Picture but no sound magnavox HD tv
check to see in audio menu for set and sat or cable box if SAP is engaged as this will (Spanish) cause no sound on certain channels.
The problem or setting exists in the set and most boxes providing signal to the set.
Mar 12, 2012 | Magnavox Televison & Video
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
We have a 42 inch flat screen that was working fine this morning before I left for work...my husband turned it off from the tv instead of the remote as I always do - we have Direct TV - when I came home I...
Does it work when you use the DVD player? Or just the problem when you are trying to use Direct TV?
How is the driect TV hooked up to the TV? HDMI, COMPONENT VIDEO, COMPOSITE VIDEO, RF CABLE THROUGH CHANNEL 3 or 4 ON TV?
Dec 10, 2010 | Digital Lifestyle Televison & Video
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Jul 23, 2008 | Televison & Video
Picture black out
Like your computer a tv has the same type of circuits, & sometimes they get glitches, maybe, but i feel you might be starting to have a problem in the 'DMD" board in your tv. Maybe not; unplug tv for 10 min to 24 hrs. I am a mit factory auth tech. good luck,.
Jan 05, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Philips Magnavox 32"
Sounds like the PLL IC or the tuner maybe going bad??. You didnt say that by NO picture NO sound, is there any light on the screen at all?? You said when you change channels it comes back alive for a bit.? This is the indication that its a tuner or related circuit problem . Now first off +these sets do not have any user serviceable parts inside them as they are all solid state and soldered in and then you also have to deal with the HI Voltage saftey issues. This is not a reapir You should attempt to do on your own as a pro should assist you in this repair. Good Luck
Jun 23, 2006 | Philips Magnavox TS3260C 32" TV
Philips Magnavox 55P9271 55" Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
