Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Not being able to connect to Internet still
Compaq Presario C770US notebook PC runnin Vista
Modem: AZTEcH ADSL+2 Ethernet Bridge
Wireless Router WBR2310
New error message:
There might be a problem with one or more network adapters on this computer
    Scholar:
  • 132 Answers
  1. Check the wireless adapter of your laptop. To do that, go to control panel then go click on System then go to Device manager.
  2. On Device Manager window, look for Network adapter. Check all the Network adapters installed to your laptop.
  3. Look for the wireless adapter installed in your laptop. Once you found it, right click on it and then click properties.
  4. Under the general tab, look for Device status.
  5. Make sure that the wi-fi button of your laptop is enabled.
Hope this helps!
Posted on Nov 13, 2008
How to connect Satellite 4090XCDT laptop to ADSL?
You computer was set up to use a modem to access the internet.
You computer does not have USB, so you cannot use Wi-Fi.
You need to purchase a 2 x PC Card Type II or 1 x PC Card Type III Ethernet card. Then you can plug a Ethernet cable into the ADSL router.
Jul 01, 2014 | Toshiba Satellite 4090XCDT Notebook
A friend of mine has this D-Link DSL-2750U router & is trying to connect his cable internet to the router but failing to do so. We suspect it is a purely ADSL router & does not support ethernet connection...
You need a router which connects to ethernet..ADSL is connected by RJ45(Telephone connection) ... Many cable companies include a router in the Modem (Verizon) others need a router to do wireless which gets connected between the PC and the Modem . the DSL-2750U is well over $2000.00.. a normal wireless router is $50-$100... a regular router gets connected by ethernet to Modem and router ,, then has 4 other connectors .. ehternet to PC.. Also requires power supply. .. wireless has to be setup for the software.
Oct 28, 2013 | D-Link Computers & Internet
How can i connect my compaq presario 1245 laptop to my cable modem via my wireless or wired router?
You can hook it up with a Ethernet cable from modem to laptop or if you have a wireless network setup at home you should be able to see your wireless network your laptop click on it and whala!! connected.
Feb 25, 2011 | Compaq Presario 1245 PC Notebook
Desktop wont connect to internet but laptop will
Is your cable modem also a wireless router?
From my search on it, it is not a wireless router.
This means you need to attach a hub or a wireless router to your cable modem so that more than one computer can connect to the internet simultaneously.
Go out and buy a wireless router. Connect the wireless router to your cable modem.
Connect your desktop to the wireless router with an ethernet cable.
Then you should have internet on your desktop.
Let me know if this helps. Give me a good rating and vote for me please.
Mar 24, 2010 | HP Compaq Presario SR2011WM PC Desktop
My compaq presario V2000 will only connect to dialup
To connect to your DSL internet you will need an ethernet port or wireless card on your laptop. Your laptop should have an ethernet port, it will look like a phone jack but a little bigger. In the off chance that you don't have an ethernet port on your laptop you can also purchase an ethernet to usb adpater. You may have a wireless card installed on your laptop, but if not you can purchase a usb wireless adapter. To use your internet wirelessly in your home you'll also need a wireless router. All of these things can be purchased at your local electronics store (walmart, best buy, kmart, frys) and usually are fairly easy to setup with the included instructions.
Feb 15, 2010 | HP Compaq Presario V2000 Notebook
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
MY WIRELESS LINSKYS HOOKED UP NOT FINDING MODEM/CANNOT CONNECT
You don't use a modem to connect with a wireless router. Connect an ethernet cable between the laptop and the router to ensure that both are working. If this gives you an internet connection then the commonest problem is an incorrect wireless key. Reset the key on the router then cut and paste it into the wireless network setup in the Control Panel. Wireless drivers are frequently updated and you should check for a newer driver.
Feb 02, 2008 | HP Compaq Presario C304NR Notebook
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
I want fast help..how to get connection between linksys router and aztech modem
first check..
Step 1:
Step 2:
Step 3:
Step 4:
Compaq presario m2000 - secondhand
This does appear to have wireless capabilities. there should be a small button to the left of the screen latch which you press to turn wireless on/off when on there should be a blue light that comes on. if you wish to use wireless to access your broadband you will need to have a wireless router / ADSL modem (depending on your supplier) you then configure the settings on the router to access the internet, then you configure the laptop to connect to the router. (there shoudl be instructions on how to do this with the router I hope this helps
Sep 28, 2007 | Compaq Presario M2000 Notebook
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
150 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
