Question about Whirlpool Dishwashers
My ADG 8983 has an Fb error, what should i be doing ?
  • emmanuelr Nov 02, 2008
    The pump ref 481236018546 has been changed but the error Fb or maybe F6 remains
  • 1,029 Answers
Hold start button down for about 10 seconds to clear it initially to re-start cycle.hope this helps
Posted on Nov 02, 2008
    President:
  • 2,712 Answers
F6 indicates a problem with the drain mechanism. It could be that something is blocking the drain. From repairclinic.com:
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Nov 04, 2008
    Genius:
  • 1,550 Answers
Regarding the error F6 it is not easy to repair .
You need to contact near by whirlpool service center to get it repaired .
Posted on Nov 03, 2008
  • 76 Answers
Fb is a fault detected with the optical water indicator. which is kinda nice cause your unit doesnt have one! basically its a fill level control issue. there are two possibilities.the water indicator in the sump is not working properly, this is the first one. remove all filters and look into sump. there is a black grid at about the three o'clock position. it has a bad habit of filling up with muck and goo preventing the black rubber diaphram (sp?) in the back from moving. you can often see white fat deposits on the grid. you can clean these with a toothbrush and hot soapy water.second is the flow meter. this is in the water matrix, located under the left hand side panel. poor connections at the little pcb are common. often a good cleaning and a pinch of the connector will solve the problem. bear in mind though that each of these individual problems ShoulD bring up there own fault codes. it is possible (though not very often) that the computer has lossed its plot. theres no easy solutions, but if you decide to take this on yourself make sure the dishwasher is unplugged. hope this helps:)
    Master:
  • 505 Answers
Is it taking water in?
check for kinked fill hose.
is the water pressure good enough?
Failing that, left hand panel off, unplug the flowmeter, plug it back on and try again.
Take the side panel off, disconnect then reconnect the flow meter. It will be working fine now.
Thanks
    Genius:
  • 1,689 Answers
The link below will show you the general steps on how to clean your dishwasher, just go through it and this may solve problem.
http://www.howtocleanstuff.net/kitchen-and-bath/kitchen-appliances-and-fixtures/how-to-clean-the-dishwasher/
hope this helps, if you have questions just lemme know
  • Whirlpool Master
  • 19,396 Answers
Try first unplugging power cord and see if theis clears the error.
  • Ginko
    Ginko Nov 02, 2008
    Fb error does not exist, if instead error is F8, that means that there is a problem with the drain system, check the drain hose, remove the appliance bottom panel and try to remove any possible obstruction using a screwdriver, taking care not to damage the unit.
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Apr 24, 2011 | Whirlpool Microwave Ovens
What oil goes in 85' jeep cj transfer case?
Dextron III ATF (automatic transmission fluid) will work in this transfere case just fine
Jan 19, 2011 | 1985 Jeep CJ7
Whirlpool Dishwasher machine (Mod. ADG 8970/1) wont start. Water is taken in. After several attempts to start an error code "F4" appeared.
Hello Sir,
This error code, " F4 " comes only when the waste outlet is totally clogged with waste and blocked. Try to dismantle the machine and locate the Waste outlet pipe and thoroughly clean it. This will reset the error which is caused.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Whirlpool WFW8300SW
Purple blotch on screen
hi..This patch can be a result of your TV 's Auto Degaussing
Coil problem. Metallic parts of a TV gets magnetized and the
ADG coil demagnetizes them. At power on you should hear a
sound,which is the ADG coil.please check the ADG coil connector
it might have been pulled out. The ADG coil is wrapped around securely
on your TV's Picture tube and power is tapped directly from the AC
Main via a plug in type connector to the TV main circuit board.
check it out..
thank u..
rate me..
May 04, 2009 | Samsung HPN5039 50 in. Plasma HDTV
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Dishwashers Logo
76 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
