Question about American Audio Car Audio & Video
Inside speakers play subs wont
My factory speakers will work but my sub wont rca jacks in radio are good and amp works
    Sergeant:
    Champion:
  • 227 Answers
You need to buy a high to low adapter.
good luck
caypianan@yahoo.com
Posted on Nov 03, 2008
I reset my radio and my subs stopped working, i used to have the option to adjust the use of the sub woofers where you can adjust the bass, treble, and balance but when i reset it the option just...
Check the fuses , on unit , then your amp. And did you use a remote to reset the radio ? Also check RCA jacks on the back of the radio !
Sep 25, 2013 | Car Audio & Video
How to hook up car radio to an amp when radio does not have RCA Jacks
They make a type of Amplifier that uses high level input from the speaker outputs. Contact a company called Crutchfield.com for details and prices. You ca also have a radio shop install preamp output RCA jacks to the factory radio, do an Internet search for shops that do this type of retrofitting.
Apr 29, 2012 | Cars & Trucks
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Sony radio sub outputs don't work at all
you may need a new head unit. it sound like you have lost the fron rca hook ups on your unit. common prob. usually cause by a surge traveling then the rca cables. i myself have had this happen and there is nothing you can do to the unit to fix it.
Sep 26, 2009 | Sony XS-V1330 Coaxial Car Speaker
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
Unwanted bass coming out of my subs
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Feb 24, 2009 | Kenwood eXcelon KAC-X812D Car Audio...
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
Car Audio & Video Logo
75 people viewed this question
Top American Audio Car Audio & Video Experts
xxxxxx xxx
Are you an American Audio Car Audio and Video Expert? Answer questions, earn points and help others
