Question about Singer 2662
Bobbin tension and needle centering singer 2662
How do i ever so slightly loosen the bobbin tension? also is there any way to get my needle more centered? it is to the left and i have the needle positioner pushed over as far as it will push without using brute force but it just won't go smack dab in the center, i've changed the needle many times so it's not bent needle and i usually have to slightly push the needle a smidge to the right to get my needle threader through the hole. thanks, nancy williams dollyllama@frontiernet.net
  • Anonymous Mar 19, 2014
    I am having difficulty lining up the needle. It is off to the left, and I cannot seem to center it. I have changed needles and done everything I can think of. The manual does not cover centering the needle.
    Problem Solver:
  • 9 Answers
I would suggest taking it to a sewing machine repair shop. I would not mess with the bobbin tension yourself, have a trained professional do it. It also sounds like you may have some other problem going on with your needle, so that would be another reason to take it in. Good luck!
Posted on Mar 17, 2009
Singer 2662-when I press the foot control the motor revs but doesn't make the needle go up and down.
Most sewing machines have a switch to position for sewing or for spinning bobbins. Make sure it is in the sewing position and not for spinning bobbins. I have several sewing machines (not your model) and they all do that if they are set for spinning bobbins.
Feb 05, 2013 | Singer 2662
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
How to thread the bobbin
Are you trying to thread the bobbin for winding or for sewing?
For sewing, make sure the needle is fully up and then release the bobbin cover plate. Insert the bobbin so that the bobbin rotates counter-clockwise. Pull the thread through the slot at the center-front of the bobbin case. Hold down the bobbin with a finger then bring the thread to the left and through the slot on that side. You should here a clicking sound when you pull on the thread. Leave 6" of thread free and replace the cover plate. Refer to the manual (page 12) for pictures.
Many Singer sewing machine manuals are available for sale or download here: http://www.singerco.com/accessories/instruction-manuals . The direct link to the manual for the 2662 is here: http://www.singerco.com/uploads/download/429_2662_efs.pdf . See page 11 and 12.
If the bobbin thread isn't feeding, clean the hook and surrounding area. Then with the presser foot down, retry. If you aren't hearing the clicking sound when the thread is pulled, you may need the bobbin tension adjusted. There is a small set screw for the adjustment but it's really easy to damage the threads. If you still have a problem, the bobbin case or shuttle race may need to be replaced (See http://parts.singerco.com/CPpartCharts/2_2999/2662.pdf for the parts breakdown).
I hope this helps.
Oct 28, 2011 | Singer 2662
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Making loops on top of fabric. I loosened the tension but it continues to loop.
try these suggestions
check your needle to see if it's bent-roll on flat surface to see if it rolls correctly
which tension did you loosen-top or bottom?
try rethreading
Sep 22, 2010 | Singer 2662
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Top thread is loose
Your needle thread tension is too tight or the bobbin tension is too loose. If it is the latter try turning the bobbin case tension adjusting screw clockwise abot a full revolution.
If that does not work there is more than likely a bit of lint behind the tension spring, so carefully remove it and clean it out.
Jul 06, 2009 | Singer 2662
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
A horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Jan 05, 2007 | Singer 2662
Singer 2662 Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
