Even running add new hardware wizard, windows not able to find out the audio device...i am not able to install audio driver from notherboard cd ... kindly help me out.. thanx.
I had a few times such a problem but not with this particular motherboard. I needed to install some hotfix from Microsoft to be able to find and install an audio device. Look here Hope you'll find your solution.
SOURCE: sound driver problem and unknown devive driver problem
Hi
C-Media Audio driver for ASRock 775i65GV
Windows XP, 2K, 9X - http://www.asrock.com/mb/from.asp?Model=775i65GV&s=&T=D&ID=162
Let me nkow if you need further help.
Regards
Mike
SOURCE: does ASRock 775i65GV supports DDR2 memory?
*********** board support only
ASRock 775i65GV motherboard memory support specification.
- Dual Channel DDR memory technology
- Supports DDR400/333/266 non-ECC, un-buffered memory
- DIMM slots: 2
- Max. capacity of system memory: 2GB
It means you can use only DDR memory.
SOURCE: update for 775i65GV motherboard AsRock
The downloads for your motherboard are here.
The drivers are at the top of the page and the bios updates are beneath those. Be sure to read the instructions for download and install carefully.
Good luck.
Regards, redqew
SOURCE: Computer auto power on
I believe the setting you
want is in the bios. It has been a while since I have been in mine. It
has to do with "restart after power failure"
And since your time/date are also off, I suspect you have a weak cmos battery on the board.
How old is the computer?
The battery looks like a watch battery. It is round and thin. It should be replaced.
SOURCE: where can i find installer for the video card of
You can get it at asrock's website. Anyway, you can get it here. Make sure to choose your correct operating system or the version of windows you are using so that you will be directed to the right drivers. If you only need video drivers, then only download the links to "VGA Drivers"
