Electrical heater (brand: Creda) was switched on and turned off automaticaly after a few second. The heater can be switched on again after few minutes later. There are only switches there : Carga input(from 1-6) and descarga output (from 1-6).
SOURCE: I am trying to fix a Sharp 27k-s100 television.
Can you use the remote control to change the channels? If not, it may be that to need to reprogram the remote to work with your TV. I just had the same problem. I have GE universal remote and have reprogrammed it to work with my SHARP 27k-s100 TV by following these instructions: http://www.ehow.com/how_9190_program-ge-universal.html The code that worked for my TV is 173. Other codes listed for SHARP are: 004, 006, 012, 029, 095, 111, 112, 113, 122, 171. Good luck!
Posted on Sep 11, 2007
bhur
  • 85 Answers
SOURCE: 32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
Posted on Jun 13, 2008
SOURCE: Vulcan electronic gas heater switches off
contacted a gas plumber
Posted on Aug 27, 2008
viziks
  • 220 Answers
SOURCE: Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Posted on Sep 12, 2008
pierre1811
  • 144 Answers
SOURCE: Rheem Model# RGDJ-10eamer sometimes lights and sometimes does not
Find the small tube that runs from the inducer blower. Disconnect the hose and see if there is water in it. If so then I suggest remounting the pressure switch that it is attached to a little higher and so that there is no droop in the tube for water to collect. Just shortening the tube will only allaow water in to the pressure switch. The second thing is with the tube disconnected at the inducer take a straightened paper clip and poke it in the orifice on the nipple attached to the inducer. there may be a partial blockage. Let me know what you find.
Posted on Feb 27, 2009
Why does my remote car starter turn off automaticaly two seconds after i remote start it? All other features work propperly. It even starts when i push the button. Unfortunately it turns itself off again...
You should consult the manufacture of the remote start unit. Search the web for what ever brand it is and they all usually have a downloadable manual. It may be a setting or a malfuntioning unit.
Oct 14, 2011 | Cars & Trucks
When i am switching on my monitor after few seconds its automaticaly getting off and stop working. what will be the problem and how i get it repair ?
Hi
Please confirm me you r using CRT monitor or LCD, check the your VGA and may be is not work properly, Change the VGA cable and try again
May 12, 2011 | Samsung Computers & Internet
What is the proper sequence for lighting the pilot on a whirlpool electric light water heater?
There is not pilot flame on electric water heater! It is electric! You just connect it to the proper inlet (cold water main) and outlet (hot water to tap), then connect it to electrical outlet, switch it on and that is all. it should run automaticaly when you open the tap.
Aug 13, 2010 | Water Heaters
Our car stereo will automaticaly off in a few minuete and it will ask a code, but when we switch off and on again then it would be ok, but in a few minuete again it will automaticaly off angd ask for a...
By entering the correct code
If you do not have it , then remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
Aug 11, 2010 | Car Audio & Video
CAN I CONNECT A CREDA 2000W PLINTH HEATER USEING A FUSED PLUG?CREDA 2000W PLINTH FAN HEATER
Yes ,you can and fuse at 13amp.
Although the correct way would be to terminate the plinth heater in a switched fused spur or an unswitched fused spur fused at 13 amp
This can either replace a single or double socket or it can be taken of the socket by using 2.5mm2 twin and earth cable.
All parts availiable from hardware store or electrical retailer
Oct 06, 2009 | Creda C362E Electric Kitchen Range
How do I get a manual on a Creda Concept Solarglo Cooker
When i turn on the kitchens rings,they turn on for 10 seconds and after turn off for half minute and this process continue to repeate again and again. The indicates of screen change allte time, and i dont know whats happen with the kooker.Please inform me what to do. Thtank you!
Apr 21, 2009 | Creda C362E Electric Kitchen Range
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
The heater won't start.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 10, 2005 | Black & Decker BDHF200 Compact Heater
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
