Question about Dell 926 All-In-One InkJet Printer
Paper does not feed
Paper doesn't feed and when you push it down it does not go in
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lets try few troubleshooting for paper Jam issue.
locate and slowly pull out the stuck paper, perform the following steps:
1. Turn off the printer.
2. Open the printer cover.
3. Locate the stuck paper.
4. Remove the paper.
5. Close the printer cover.
6. Power the printer back on.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.
6. Remove any visible obstructions.
7. Reinsert the paper.
Adjust the Printer Paper Guides
Extend the front paper support on the printer.
Try a Different Piece of Paper in the Printer
1. Take the top 10 sheets off of the **** of paper.
2. Verify that the remaining sheets of the **** are not wrinkled or dirty.
3. Replace the remaining part of the **** back in the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Try a Different Type of Print Media
Many image quality and paper feed issues are caused by the type of print media being used.
Try a different type of print media that is specifically made for this printer.
When there is no different print media available, take out the top half of the stack and flip it over.
Try holding the printer upside down and shake it moderately
Make sure you remove all the cables from printer before performing it
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Posted on Nov 07, 2008
My Epson 1400 wont pull the paper through when I hit the print button. But when I insert a sheet of photo paper and hit outside printer button it will pull thepaper through but wont print
Hi
First off, the simplest solution is to try to clean the rollers of dust. If you can access the rollers, especially while they are spinning, this would be best. Get a damp cloth either with water or rubbing alcohol and wipe the rubber down, and retest your machine. Most of the time this is cause by the paper pickup rollers, which are made out of plastic or rubber, getting too dirty/slick to properly pick up the paper. Remove all the paper and the paper tray if you can. Using a long qtip, clean the rollers with alcohol. If that doesn't work, or can't be done with your printer, take all the paper out but one sheet. Spritz some alcohol on the bottom of that sheet and smear it out so it covers the entire width of the paper up about 2 inches. Then try to print a document that is a blank page. After either of these methods wait at least 4-5 minutes for all the alcohol to dry before trying to print again.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 15, 2011 | Office Equipment & Supplies
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
Hi, My Canon MX310 all-in-one is only a couple of years old and lately broke down. The problem is it doesn't take the paper correctly. Shrink it at the start of printing and shows that there is not...
My PIXMA 6000 has a paper tray on the bottom or else you can load the paper from above.
When the paper tray contains paper and is loaded it moves a switch that alerts the printer that there is paper available to the printer.
When loading paper from the feeder on the top of the printer there is a bar that kicks out from behind the paper that pushes the paper in to a roller on the other side. The roller grabs the paper and feeds it in to the printer. As the paper enters the printer a sensor detects it's presence.
Jun 12, 2011 | Canon PIXMA MX310 All-In-One Printer
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
Paper jamming
You have almost certainly got a foreign object in the paper feed path as there is nothing on the L/H side that should cause an obstruction. First of all turn the printer off & disconnect all cables. Turn the printer upside down and give a good shake, with luck the blockage should fall out. If not then you need to be a bit brave, make sure the print carriage is parked fully right and out of the way. You will need an A4 (approx) sized piece of stiff cardboard such as the backing from an A4 note pad. Insert this into the paper feed locating it between the feed rollers on the R/H side. Then push quite firmly to overcome the spring pressure, when you feel it push through about a half inch stop and open the printer to see what is being pushed through. Push the card fully through and retrieve the foreign object (I have found everything from paperclips, curtain hooks and even a golf tee!). Push the card through fully and out of the printer. Always remove paper jams etc, in the direction of the paper feed whenever possible as pulling anything backwards can dislodge or break the sensor flags.
Hope this helps. Please take a moment to rate this solution, thanks.
Apr 10, 2009 | Epson Stylus Photo R300 InkJet Printer
Paper feed
Try pushing down on the back of the paper feeder. Also try lifting the paper tray up from the back of it.
Mar 03, 2009 | Konica Minolta magicolor 2300DL Laser...
Won't feed paper
Hiya .. Your roller guides.. just need a general clean... and the sensors located just on the inside of the printer at the bottom where the paper sits ..
Regards Faggly
Mar 25, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer
If it is not pushing the paper out of the tray, you should first try taking a soapy cleaner like fantastic or formula 109 and clean the feed rollers and see if that helps.
The paper tray also lifts up and down to feed the paper so the gear that drives the tray up and down may be broken.
Slen the rolls first. If that doesn;t last long. Say in a day or two it starts misfeeding again, the rollers will need to be replaced.
Mar 23, 2008 | Office Equipment & Supplies
Dell 926 All-In-One InkJet Printer Logo
90 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
