Question about Frigidaire GLER642A Electric Dryer
Very loud I have a GLER642A model and when i have it running i have a very loud screching noise but i do not smell anything getting hot. Any answers?
  • 550 Answers
Rubber tired drum support rollers or drum felts have worn
open case and remove drum
as described in any of the 'change belt' posts
examine rollers. at rear of drum
if damaged replace in pairs
If rollers are good(unlikely) examin felts and nylon glide surfaces
Posted on Nov 03, 2008
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
Loud noise while running
Hello. Did you get an answer to this inquiry. Mine is doing the same thing. Smell of burning plastic; continues to fill and drain at the same time?!! I have to manually shut of water to stop the water and then manually set to spin so it will drain!
Mar 22, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
When Dryer is on it makes loud banging noises almost like the cylinder is hitting the sides. It also seems to be excessively hot even set on low heat, and has an almost burning smell inside after running.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 15, 2010 | Asko T700 Electric Commercial Dryer
MODEL GLER642A - Dryer started making a very loud vibrating sound the other day. It tumbles and dries fine. The noise gets louder with a smaller amount of clothes than with a full load. It is on a level...
heatman101
Sep 14, 2010 | Frigidaire Dryers
Dryer has a noise after it is on for a min. we changed the bearing with a kit and it still has the same noise. the drum guide looks fine. what else can it be
check idler wheel and tentsion bracket...it sounds like the lil wheel on the idler arm is wore,,,but also check down the blower housing for anything that might be stuck..
Jan 03, 2009 | Frigidaire GLER642A Electric Dryer
Brand new Dryer with loud noise and hot
contact bosch for factory service on the unit
May 10, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
112 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
