Question about Creda C361E Electric Kitchen Range
My grill does not heat up properly
The grill gets warm but does not get hot. Even the element doesn't seem to have a glow to it. I've tried putting the top oven on but this doesn't seem to help either...Has anyone else had the same problem....Or can they tell me if I need the top oven on as well???????
    Scholar:
  • 160 Answers
Have you tried to reset the breakers? one may have kicked and not thrown both of them so you would only be getting partial power.
Posted on Dec 05, 2008
How can I tell if my water line tank heating element is broken? Should it get warm to the touch?
no it should not. If fridge fan is working water should not freeze.
check for fan motor operation.
Apr 03, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
Had the back off and heating element out, gets warm then no heat , should the element glow red hot , or is one not working and therfore cutting out the thermal trip
IT SHOULD GET PRETTY HOT AND STAY THAT WAY FOR A BIT? U CAN CHECK IT WITH A METER SHOULD SHOW ABOUT 12000 OHMS AND CONTINUITY BUT i SUSPECT U NEED TO CHECK UR THERMOSTATS AND FUSES CONCENTRATING ON UR HI LIMIT AND UR CYCLING MAYBE EVEN UR MOISTER SENSOR SWITCH
Mar 05, 2015 | Dryers
My maytag dryer gets way to hot. you cant even get your near heating element. you can even see it glowing. what could cause that.
Were you running the dryer without the lint screen in place? sound like you got something on heating element. Also the heating element does glow orange when it's on. If it keeps on getting too hot, there is a sensor that shuts off element after a certain temp. This may not be working right. Just what I came across working on my own in the past.
Sep 11, 2012 | Dryers
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
My electrolux EOB5610 wont heat up....the fan works and the grill works but will not reach any sort of temp !!!!
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 02, 2011 | Electrolux EOB5610 Ultrafan Electric...
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Oven wont heat up, the grill does and the clock, timer works
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection. Thank you for your time and thanks for choosing FixYa.
Feb 28, 2011 | Bosch HBL 5052 Electric Double Oven
The right front burner will not get hot. It is only warm never hot. The burner doesn't turn bright red even when tuned up on high.
hello, try changing that front element(burner)if its easily removable to another side that is working normal. If the element is still dull not heating or glowing normal then replace the element, but if it does, then there is something wrong with the front right element switch or the receptacle.
Oct 30, 2010 | KitchenAid Kitchen Ranges
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
3 of 4 heating elements on Kenmore glass cooktop do not heat properly. They come on and then cycle off and on and never reach a cooking temperature. Only one of the 4 works properly. I believe the...
this might be normal behavior is the unit still heating and boiling items? has the unit worked differently in the past?
see below
Why the smoothtop radiant cooktop element cycles on and off
  1. Save as PDF
  2. Share
Table of contents
Does the radiant heating element cycle on and off?
  • The surface cooking area may glow red when a heating element is ON.
  • Some parts of the surface cooking area may not glow red when a heating element is ON.
  • The warming zone element (on certain models) will not glow red.
  • Radiant elements have a limiter that allows the element to cycle ON and OFF, even at the HI setting, to prevent damage to the ceramic cooktop. This is normal operation.
  • The radiant heating element retains enough heat when off to provide a uniform and consistent heat. The surface will still be hot even though the element has cycled OFF.
  • Cycling at the HI setting is normal and can occu
Feb 26, 2018 | Kenmore Kitchen Ranges
Creda C361E Electric Kitchen Range Logo
223 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
