Question about Fuji FinePix S5000 Digital Camera
White Screen Hi Just like JayJay reported on 26 Jul 2006, my S5000 went white screen yesterday after previously behaving ok. I've tried all modes from AF to Manual. Like JJ I can view previous frames which view OK. I've changed batteries, tried to balance exposure. In Appature mode the reading is 2000 f8 and will not vary. Hopefully someone out there can offer a solution ? lenk
    Champion:
  • 217 Answers
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Posted on Sep 08, 2007
SOURCE:
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
Jan 04, 2010 | Fuji FinePix S5000 Digital Camera
White screen!
Hi
A white screen is associated with no signal being sent to the screen and not a fault with the actual screen itself.
Often this is caused by a loose connection where the wiring for the screen plugs in to the circuit board there is a little plug that can work itself loose and cause this.
If you feel confident about it you could open the camera and trace the LCD wiring to the circuit board. Ensure the little plug has not worked loose from its socket on the board.
The only alternative to this is that there is a component malfunction and this will require a service repair.
Hope this helps. Thanks for using FixYa.
Dec 22, 2009 | Fuji FinePix S5000 Digital Camera
I reformated my computer and had it on hibernate and went to sleep.I woke up and now the screen on my desktop pc just flashes about every 3-4 seconds.the screen stays black the flashes with white streaks...
Hi there
i read your report. OK go to your power options and turn off your hibernate and restart your computer.allot of times after you have reformatted your hard driver. the hibernation doesn't work correctly. Try this tip and let me know how it goes. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
White screen
I have same problem. Everything is ok, but all recorded images and video are white.
Jul 13, 2009 | Fuji FinePix S5000 Digital Camera
White screen
I called sanyo ,they had me try this and that and then said a tech guy would call back he did i am taking the tv to a repair shop and it will be fixd under the warranty.
Jan 11, 2009 | Sanyo DP23625 23 in. LCD Television
White screen
Join the club of many s5000 users.
Your CCD is faulty.
No DIY repair possible because no spares from Fuji available.
A Fuji repair is not worth it.
Jan 08, 2009 | Fuji FinePix S5000 Digital Camera
Fuji S5000 - screen is white or white and black in camera mode. Normal in picture viewing mode
Try resetting your camera.
Press Menu/OK -> SET-UP -> On page 3 there is a reset menu. Confirm selection. Camera will be set with all factory adjustments.
Nov 25, 2008 | Cameras
Fuji S5000 Digital Camera--White EVF/LCD Screen
i was told by fuji it is the ccd or cmos sensor effectively the eye of the camera it is faulty and needs replacement fuji said it would cost £90 to replace as the newer model of the fuji is only 145 i opted to buy a new camera so i bought i differant brand and am very happy with my dmc tz3
May 28, 2008 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000
This appears to be loose connector to the motherboatd from the screen.
Try gentle squeezing of the casing near the bottom of the body
This may do the trick- otheriwise it is a workshop job and frankly not worth the cost - the money would be better spent on a more uptodate camera.
Nov 27, 2007 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
332 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
