Question about Toshiba Portege M200 Notebook
MS Word 2007 - Page won't advance
When typing text, the screen/page won't advance when I come to the bottom of the screen, so I can't see what I'm typing. I received an email that someone answered this problem, but there was nothing written as to a solution.
this is a huge problem for someone who types constantly on big text projects.
MANUAL FOR MS-6785
http://diplo-best.com/review/MSI/MS-6785
Left side of the page under the advertisement, to the blue -
Download your MSI MS-6785 user guide or user manual
Click on the above.
Underneath the Red large banner - Download your MSI MS-6785 user guide or user manual, click on the blue underlined -
security code.
Scroll the page down a little.
Left-click in the box to the right that has - copy here - to the left of it.
(Arrows flash in and out on each side of the box)
Type the number/letters you see.
Then click on - Download the user guide - underneath.
A small window will come up on the right. Open with:
,should have Adobe Reader in the box to the right of Open with:
If not click on the Down Arrow to the right of the box, and in the list click on Adobe Reader.
Now click on OK at the bottom of the window.
After the file has downloaded to your computer, the Adobe PDF file will open up.
There is your MSI MS-6785 motherboard user manual.
Sounds like a lot of bull to go through, huh?
Keeps robots (Bots) from trying to download.
I'm looking at the motherboard manual right now.
File name?
4d8b61b28d97054bace386f363a9a4a.PDF
"Thank you for purchasing the MS-6785v1.X Micro ATX mainboard.
The MS-6785 is based on SiS 648FX and (Ampersand) SiS 963 chipsets for optimal system efficiency. Designed to fit the advanced Intel Pentium 4 processors in the 478 pin package, the MS-6785 delivers a high performance and professional platform solution."
Mainboard Layout - Page 4
Quick Components Guide - Page 6
Power Supply - Page 13
Connectors - Page 19
Jumpers - Page 29
Anything I can help you with if you cannot download the manual?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 15, 2012 | MSI Computers & Internet
Ms Office 2007 key
the key is ---
KGFVY-7733B-8WCK9-KTG64-BC7D8
Dec 30, 2010 | Microsoft Office Professional 2007 Full...
When printing booklets the top and bottom margins are too large making the print very small. How do I change the margins and the font size?
The margins of top and bottom and print size and font size are all the options that given to you inside the software that you are using to print the books. Now you have not mentioned the software that you are using. The two most prominent software for writing and printing books are MS Word 2007 and Adobe Writer.
Lets say you are using MS Word 2007. When on the top menu bar you click "Page Layout" button. Then you play and select the parameters that suites you requirement like "Margins" button meets your requirements. You can also check with the "Size" for the Print page sizes. To change the font size in MS Word 2007 highlight the text you want to re-size and then right click after placing the mouse pointer on the text the integer number you will see will be the font size and you can change it according to your liking.
One good tip for you for most quality software that are used for printing is that they offer an option "Print preview". It will show you how your document will look like before you print it.
Good Luck!
Dec 20, 2010 | HP LaserJet P4015N Printer
How do I set the on screen right margin in Outlook 2007? Can't find this anywhere. I did find some mention of changing the margins in the normalemail.dotm. I tried this, but the on screen margins didn't...
1. Office Button --> Print --> Page Setup --> Memo Type
2. Print layout shows wrapped text, that's disabled in MS Outlook 2007, you can customize quick accrss bat fot it:-
Office button --> Customize --> Enable all tools --> Select Print Layout View
Apr 07, 2010 | Microsoft Office Outlook 2007: Windows
Having problems printing 11 x 17 calendar on Xerox 7335. Print monthly view of MS Outlook 2007 calendar from MS Calendar Printing Assistant and the calendar does not fit page. It shrinks the margins of the...
Try using the Postscript Driver. Once it is installed, you should be able to open the Properties > Advanced > Printing Defaults > Advanced > Image Options > Margins and set it to None.
Nov 18, 2009 | Xerox WorkCentre PRO 128 Copier
Front page in MS office 2007
There are different "packaging" options for MS Office 2007.
When you installed MS Office, did you choose "Advanced" install,
and did you enable/disable the installation of Front Page?
Click Start.
Click All Programs.
Click Microsoft Office.
Do you see "word" and "excel" and "powerpoint" and "front page" ?
Just some of these programs?
Sep 18, 2009 | Microsoft Office Professional 2007 Full...
How do i switch off ms word 2007 auto correct?
Open ms word 2007 then go to tools -> autocorrect
then disable check box for which you not want autocorrect.
Aug 24, 2009 | Microsoft Office 2003 Basic Edition...
MS Word 2007 -
You can go to View/Normal view, or you can press the Paragraph button (Show/Hide Paragraph). Both ways you'll get the Page break shown on screen
Sep 08, 2008 | Microsoft Office Professional 2007 Full...
Lables do not work
Dear Carol this sounds like a page setup problem more than MS word version problem. You might like to re adjust the page size, dimensions and text to rectify this problem. You can also try emulate same dimensions from your older verion of MS word into new one. There are alot of things that are not compatible with new MS word like file extension .docx cannot be opened in previous versions.
You can also use image editing softwares like photoshop and corel draw for making labels, way better than MS word.
If this was helpful kindly press solved.
Nov 08, 2007 | Microsoft Office Professional 2007 Full...
Toshiba Portege M200 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
