Toshiba vcr W522CG
I pressed a button and now I can't get the program button to work? the tv channel is fuzzy and I can't get the menu to come up . I realize it is the 3 4 channel problem but how do I fix it?
  • 1 more comment
  • SANDRAFEVANS Nov 06, 2008
  • walker_44 Nov 07, 2008
    I had to turn my TV to channel 4 and then press the program button and it worked then. I then changed the vcr back to channel 3 and the the TV back to channel 3. I had obviously changed the VCR to channel 4 and then the menu program button will not work as they are not on the same channel
  • SANDRAFEVANS May 11, 2010
    YES IT WORKED . THANKS.........
Start over set the tv on 3 and then the vcr . then plug in the vcr and start over
Posted on Nov 06, 2008
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
Can get only 1 channel to program on my toshiba
hi if the tv has dtv just select air digital only thanks
Mar 25, 2017 | Toshiba 40RV525U 40 in. LCD TV
Program toshiba tv remote ct-885
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
    Codes to Check:
    013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
    0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Mar 31, 2012 | Toshiba CT-847 Remote Control
How do i program my channels
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
6. When channel programming is complete, the message "COMPLETED"
7. Press CH UP or DOWN button to view the programmed channels.
Dec 14, 2010 | Toshiba 26HF85 26" TV
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site.
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
Not enough channels
The history of broadcasting is one of adding more and more channels. The older the VCR, the less cable channels it will get.
Jan 01, 2008 | Toshiba W522 VHS VCR
Program button goes to fuzz channel, no regular channels show up
Yup, I went through a lot of grief one time only to discover the old 3/4 channel switch!
Dec 24, 2007 | Toshiba W522 VHS VCR
Press Menu, press up and down arrows to choose the Input Select option then press side arrows to set the channel. Tuner will automatically cycle through all available channels in your area. After the Auto channel search is complete make sure the Channel source is set appropriately (TV or CATV) by pressing up and down arrows and chossing the correct source by pressing the side arrows using the channel setup menu. Press Menu to return to the TV screen. Use CH/TRK arrows or CHANNEL arrows on the front panel to cycle the DVD+VCR through the channels in memory.
Sep 02, 2007 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
