Question about HP Officejet 5610 All-In-One InkJet Printer
Colors printing with white lines
Changed blue cartridge.
Problem: do not see blue ink on paper, pink printing with white lines; sample color page (with alph & color swatches) print with lines in between each so there are no true green, orange, etc == no solid color
I have: insured each cartridge is pushed into sockets; realigned print heads; turned printer off & disconnected power cord to printer
Help! I have the L7650 officejet all in one and it started doing the same thing. I changed the print cartridge again and it did not work. Contacted HP and after one month and numerous techs not helping, they sent me a different printer because they said it was a hardware problem. When I set up the replacement printer, it still does not print blues or greens.
  • lskinner48 Nov 02, 2008
    11-2-08 pm, I have the printer connected to 2 computers in the same room. One is running XP and the other is Windows Vista. I have the printing problem on both computers. I checked the drivers listed on each computer and they are totally different as I had to download the correct ones that would run on Windows Vista. I followed each and every step that the HP techs told me to do, I ran the diagnostic for the printer heads and it said they were good, but "monitor" the magenta and cyan.
  • HP Master
  • 6,487 Answers
If this is a replacement printer and still have the same problem so its not a problem with the printer may I ask since this is a replacement printer did you still use the same cartridges that was use on your old printer? if yes try to do a cleaning use the utility of your printer that is installed to your computer...
Posted on Nov 02, 2008
    Scholar:
  • 155 Answers
Mostly the company is right it is the hardware problem.if under warranty get it replaced.
or it could also happen because the ink in the cartridges get over.replacing the cartridges could help.
but if the cartridges are new its definately the hardware problem.
thanks.
  • HP Master
  • 13,433 Answers
Possibly a problem with the drivers on your computer, if you copy directly on the all in one, does it come out correctly? If it comes out correctly then its a issue with your computer.
If it doesn't copy directly from the scanner and print correctly then it must be a hardware problem or a problem with the cartridges / print heads.
    Guru:
  • 1,894 Answers
Did you try new and latest drivers by removing the old drivers?
if not try that first sir
  • 3,037 Answers
Have you tried redownloading your printer drivers from the hp website or off of the installation disk?
If not try it, is so, let me know and we will go from there
  • Benjamin Patri
    Benjamin Patri Nov 02, 2008
    alright, do you have extra print cartridges, if so, try those, otherwise give the ones you have a good shake to help get the ink to the bottom and also make sure the contacts are clean and then apply a kleenex to the bottom of the cartridges gently to make sure ink is coming out, and then let me know the results
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
I have been printing photos and they have come out beautiful. Suddenly the colors are all muted, and brown hair has a green tint. My printer is an HP 6180. Nothing has changed - same paper, ink...
It sounds like one of the colors is not printing correctly. I would suggest , opening your hp solutions center programs and under tools you will find an option to clean the print heads. Follow the procedure to cleans the print heads, after cleaning open control panel on the computer and depending on the operating system click on "printers" (XP) or "devices and printers"(vista win7) right click on your printer( hit your right mouse button) select " printer properties" click on print test page. This page will print out showing each of the colors separately. You should see black, blue, pink and yellow. If one of these colors is missing or muted you will now which color is cratinging the issue. And at that time I would try changing the corresponding ink cartridge. Hopefully the print head cleaning will resolve your issue
Feb 11, 2013 | HP Photosmart C6180 All-In-One InkJet...
The MX860 is making all color copies and printed pages pink. Any thoughts? It has plenty of ink in other colors.
Hello ! Here is your solution.
Your ink i.e. Cyan & yellow were malfunctioned so remove your cartridge and rub its head with soft paper until your two colors stain on your paper.... thanks
Sep 07, 2011 | Canon Pixma MP800 All-In-One InkJet...
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
The printer does not print reds and pinks
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy..
Dec 26, 2009 | Kodak ESP 5 Printer
Printer is printing wrong colors
Make sure it's the right ink cartridge for that model printer.
Check if any of the colors is out
Try running a calibration on the printer to make sure heads are lined up properly.
Link to the manual - Aligning print cartridges is on Page 70.
http://h10032.www1.hp.com/ctg/Manual/c00905552.pdf
Apr 06, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
16 people viewed this question
Ben Johnson
