Question about Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB
2 hp vertical sta-rite well pump
Runs fine but does not draw water (or very little.) everything in the well has been check out (ok) some water leakage from upper portion of punp. (seal?) would appreciate any advice. Dee
    Problem Solver:
  • 17 Answers
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
Posted on Mar 05, 2009
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
I have a 1 hp Sta-Rite Centrifugal Pump, MPRA6#-147L. When on, water is coming it but the area with with filter is not filling up. I get no pressure on the filter and very little water is going to the...
CRACKED LID BAD LID O-RING,SUCTION LEAK, OR CLOGGED IMPELLER, LOOK AT YOUR BASKET IF IT HAS CRACKS, CHANCES ARE THE IMPELLER IS GOT **** IN IT. SPLIT THE PUMP AND CLEAN OUT THE IMPELLER , GET A NEW BASKET ASAP.. REMEMBER TO (PRIME THAT PUMP) AFTER ANY REPAIR !!!!
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jul 23, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Can get the pump to prime but not get to full suction water circulates but doesn't develop any head pressure
make sure intake union tight or leak on intake if ok check impeller for debris or pump top seal
Jun 18, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Pump appears to be running properly but is not moving the water
Make sure there is an o-ring on the lid. Fill pump with water and then appy a little petroleum jelly on the o-ring and tighten hand tight. Start pump.
Apr 26, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
When I turn on my STA-RITE 1.5 HP pump, it makes a humming sound.
A humming noise is fairly normal if the pump is running and pumping correctly. I am guessing this is not the case. Usually it is just a stuck impeller that is the culprit. Power down the unit and open the pump housing to access the impeller. Then gently turn the impeller feeling for resistance (some resistance is normal from the magnets of the motor). If everything seems ok close and secure the pump housing. Try powering the unit on and see if it starts up correctly. If it is still having issues manually prime the pump. If the pump runs correctly for a few minutes after manually priming but slows or stops you have a leaky seal or fitting to find. Finding the seal is not hard but will take a little time and patience. With your garden hose, very carefully run water over each joint and fitting with the pump running. It will take a minute or so of water running over a leaky seal for the pump to prime so take your time. Make sure not to get water on the motor as it can deliver a very nasty shock and destroy the motor. If none of this gets you up and running the cause may be the motor is bad and needs replacing.
Mar 19, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Apr 03, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
I have a sta-rite pump it will prime but will not putout water
COULD IT HAVE A SUCTION LEAK PULLING IN AIR? RUNNING BACKWARDS? BYPASSING INTERNALLY ALL THE TIME? COULD YOUR DISCHARGE HOSE HAVE A RESTRICTION IN IT SLOWING IT DOWN? HOPE THIS HELPS, JODY
Aug 31, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB Logo
292 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
