Question about Kenmore Elite 45986 Front Load Washer
Kenmore front loader ,, fab softner will not empty
Took apart the tray ,, cleaned out all the holes ,,,, still will not empty ,,,, bleach and detergent tray work fine ,, what could be wrong
    Sergeant:
    Champion:
  • 324 Answers
Your cold water may be the issue, turn off your water and check the screens to the cold water side. make sure the machine gets cold water.
Posted on Nov 03, 2008
The part where I put the detergent, fab. softener, and bleach...is always full of water after it runs. It's mainly in the fab. softner/bleach area. I don't know why it's holding water???
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which needs a thorough clean, paying particular attention to the sentences in BOLD
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out clean all of the tray but identify in particular which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube
but on others the cover is part of the tray's plastic top. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 13, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Re: Kenmore Elite Washer 45996-there is mold in detergent and softner container but more on the holes above it when I pull that tray out to clean it--it is very difficult to clean those holes upside down....
The most effective way to clean mold is with bleach. If you have an empty spray bottle, mix a solution of 1 part bleach to 4 parts water. Use the spray bottle to direct the spray at every affected area and let sit for about an hour. Now, put a small amount of bleach in each container (2 ounces) and directly in the tub itself. Run a full wash cycle with (no clothes in the tub) the settings for whites. When the cycle has ended you may want to run another empty cycle if you can still smell bleach to be sure no hidden residue gets on your colored clothes. Be careful when spraying the bleach you don't spray towards yourself.
Nov 30, 2010 | Kenmore 45996 Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
I have black mouldy stuff at the end of each load. wf-t755th
Hot , hot water and lots of bleach or pool chlorine will clean it out ( run it with no cloths just hot water and bleach) Stop using fab softner.
Nov 11, 2009 | Dishwashers
The softner tray doesn't empty into the machine.
you could have a glogged up dispenser housing ,or a valve that is not working , each one has a valve that injects water through little holes into the dispenser.could be a bad valve, dispenser housing or enen a board. hope this helps
Sep 19, 2009 | Kenmore 43142 Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Cleaning front loader washer
hi. thanks for the question . No damage is done. just pour clean water in the dispenser. thanks the appliance doc
Sep 30, 2008 | Kenmore 44072 Front Load Washer
There are little holes for the liquid to release form in the cups.
Check that the holes are not clogged!
Sep 02, 2008 | Kenmore 22062 Top Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore Elite 45986 Front Load Washer Logo
120 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
