Question about RCA R52WH73 Projection Television
I have a 52' rca
I also have a bow and the colors are all srewy as well just wanted too know if you fix the prob. please help I also have a 52 in. RCA projection that is 2 1/2 years old and it has the bowing problem and seems to be 3D as well this happened all of a sudden I was reading that if you do not have the conergence that it is an easy repair. Any help that you can give would be much appreciated.. Thank you in advance Fred
  • fubar1800 Nov 07, 2008
    I have a RCA projection TV that has a bow in the screen and the color seems to be 3D the set is 2 1/2 years old model # HD52W59YX39 this happened all at once with no prior problems. I recieved one e-mail asking if I unpluged the set and yes I have.. please help
    Fred
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to reset the menu setting!!!
Posted on Nov 07, 2008
    Guru:
  • 1,894 Answers
Have you tried a hard reset first by leaving the unit unplugged for one night?
how old is this unit?
Posted on Nov 02, 2008
The picture is bowed and colors separated
this is called the fl231 fuse problem or it may be read this and it might help you or someone fix it inexpensively.http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in let me know how it goes
Oct 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bowed in on both sides. colored lines everywhere
Open fuse/bad connections on HV ckt board and one or two bad capacitors.
Mar 22, 2010 | RCA D52W19 52" Rear Projection Television
It seems the picture has gone bad on our our RCA 52" Model No. R52WH73 projection television. It is only 3 years old. The picture is bowed in at the top and bottom and the color is off. Will it be cost...
Your convergence ICs or convergence board is bad. More than likely it is the convergence ICs. About a $100 fix from a reputable repair shop. Hope this helps. If you need more info let me know.
hardrocko
Jan 25, 2010 | RCA R52WH73 Projection Television
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
I have rca 56wh78 56" with a bowed screen
You need to replace the FL231, DL231 and CP230 You can get the parts and instructions at the following link cost about 12.00 total. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 30, 2009 | RCA P52937 52" Rear Projection Television
Colors seperating and Screen bowing
The convergence circuit is not working. There are bad solder connections on the sweep board and a small fuse is open. this is not easily done yourself unless you have a technical background but an RCA tech can fix this easily.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca projection tv is blurry
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
I have a 52' rca
determine if you have a conergence problem. check out the article fl231 problem under tips and tricks
Oct 08, 2008 | RCA R52WH73 Projection Television
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH73 Projection Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
