Question about Samsung V25 CXTD 2000 Notebook
Switch to external display
My laptop screen is broken, I´m try to use my tv for the display, I have the cables plugged in can somebody please confirm what buttons I have to press so I can use the tv as a monitor ?????
  • mt323slv Nov 02, 2008
    TV is connected fine. I have used this before on this tv but can´t remember which buttons to press on the LAPTOP !
    I can´t go to graphics cos I can´t see the laptop screen !!!
  • 488 Answers
Please ensure that the TV has a compatible input for connecting laptops etc..right click on empty desktop..go to graphic options u will see an option as output to.(if the tv is connected properly)
.hope it helps!
Posted on Nov 02, 2008
  • 1 more comment
  • Lalit Varadpande
    Lalit Varadpande Nov 02, 2008
    please try pressing the function key and the f5 or f4 button..each laptop has its own function button for enabling external display,for example my HP has f4 key so i need to press function key and the f4 key together....also try the right click option i told u about..hope it works!
  • Lalit Varadpande
    ok i understand..did the function key thing help?(sometimes u may have to do it twice)have u restarted the laptop with the tv connection on?
  • Lalit Varadpande
    please look on the function key icons..there will be a rectangle thing with a box inside..
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
I'm trying to get video on my tv from the computer. Nothing works. I have tried fn f5 to switch from computer screen to tv, no good. Is there a switch that turns off external video or fn keys?
What computer (make/model) are you using, what OS and what cable between the devices?
Make sure that the port that you are using to connect the computer and the TV is enabled. This may be in the BIOS.
Make sure the input is set to PC (for VGA) or HDMI on the TV. For the HP laptop running Windows 7 Home Premium, I can enter the Display settings by right clicking on the desktop (anywhere there are no running programs or icons). Then choose Graphics Properties. In that window, I can choose the external monitor, dual monitors or the laptop's screen. Then click Apply and confirm the new display options (on the appropriate monitor).
For my desktop, with Win7 Pro, I start with the old monitor is plugged in (power and data) and turned on as well as the TV (DVI to HDMI) and start the computer. Then by right clicking on the display, choose Screen Resolution and then select the TV and the resolution for that. (Since the tv and the old CRT monitor have different screen resolutions, I do not use the dual monitor mode.) Since I know both graphics adapters are active, if I unplugged the data cable for the old monitor, it would probably find the TV without this step.
Please note that some TVs with HDMI input do not accept a computer signal on the HDMI port. In that case, you would need to use the VGA port or a converter.
I hope this helps. I'll provide additional help if you give specifics about your TV and computer.
Mar 23, 2011 | Computers & Internet
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
When i switch on vertical lines all over screen moving lines horizontally last night eventually settled and picture fine. this am no such luck any tips
Hello !
This problem can be brought about by less volage going to the LCD or having faulty flat cable ( broken) so you need to check this lcd cable if fine.
get another LCD ie just to confirm the state of your LCD I mean swap it beacuse the LCD could be damaged during drops .
Last but not list get your multimeter get the voltage readings going to the LCD.
Check if the lcd cable is seated correctly on its slot
Good luck
Nov 12, 2009 | Dell Inspiron 9300 Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
THE SCREEN IS BROKEN ON LAPTOP CAN I CONNECT IT TO MAIN COMPUTER SO I CAN USE SCREEN ON THAT
You may need to press a key combo to switch displays. Many times this is Fn + F7 or Fn + (some F key)
You may have other problems with the system that prevent the display from working.
May 06, 2009 | Computers & Internet
My screen wont turn on
Hiya, have you tried plugging in an external monitor to the Blue VGA port of the laptop ?
If so, do you get any display then ?
Hint : you need to plug in the external display 1st, then turn on the laptop. If the External monitor doesn't come on, then you may need to press the Function key on the laptop & the F4 key (Or whichever shows a monitor logo) to get the laptop to switch to external monitor.
If you CAN get display on the external monitor then the problem could either be that the Invertor for your laptop screen has blown, or, the backlight for your Laptop Screen has broken, or the Laptop screen itself has gone faulty. In rare cases, the cable from the Laptop Motherboard to the screen may be faulty or have come away form the connector on either end.
Hope this helps.
Mar 19, 2009 | HP Compaq Presario F750US
Samsung V25 CXTD 2000 Notebook Logo
110 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
