Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Washing coming out REALLY HOT even after cool spin
Hi After doing a spin on my washer the washing is coming out really really hot and still damp (even after the cool down spin). In fact it is so hot inside the machine that is is impossible to remove the washing.
This might be too easy but you have definetly check that the pipes are the right way around that connect your washer or you have not accidently connected the washer to the hot water, the 3135 only has 1 connection that shuld only have cold water put into it. This would also effect it drying capability.
Posted on Oct 27, 2006
SOURCE:
How do I get hot washter
The problem with getting hot water to today's modern washers is really an old problem. In the days of the old top loader that used 20-25 gallons per load, hot water washing was fine. Today's washers only use 4-8 gallons of water. And they bring the water in not in one spurt, but often in short, cyclic bursts while tumbling the clothes to get them uniformly wet. The problem is in the water lines themselves. Water lines are typically uninsulated, and the water between the hot water heater and the washer will cool rapidly when sitting still, especially if the water lines run in a concrete slab or in a crawl space under a house. If may take 2-3 gallons of water before the water gets really hot. Add to that the fact that we have been conditioned to turn our water heaters down to 120F or less and you'll find that HOT water in the washer is barely tepid. Use of a tankless hot water heater at the washer is the best solution, but can be costly to install.
Mar 12, 2015 | Washing Machines
Hi! My neptune tl does not seem to have very hot water. I run the washtub next to it until the water is hot, but if you pause the machine, the water that it is filling with is really cool. Cooler than...
What happens if you turn of the cold water valve at the supply and do a hot fill....leave the Hot water supply valve open? Do you hear water filling the wash tub or do you error out with a NF error code for no fill?............. D*ick
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
Water is not hot enough
What a great energy saver response....run water through another tap in the house in order to fill the pipes with hot water! I have the same problem; cannot even get WARM water in my tub. I have 2 solutions: #1, on my incoming water pipes are regular faucet handles which I am going to attach a hose on the hot side that will reach into the washer and manually mix the temperature. #2, purchase an old refurb washer at a used appliance store that HAS a hot-water setting and hope they will take the "wonderful, new energy saver" as a trade. There are just some times you really need HOT water. I can't imagine washing diapers in cold, although I haven't had to do that in many years. Energy saving factory settings: capital "B", capital "S"!!!
Mar 30, 2009 | Washing Machines
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Hot water on cold water wash or rinse
hmmm..now that's really interesting..that's a function of the control board..methinks you have an error in the panel and control center.
Mar 09, 2008 | Kenmore 44072 Front Load Washer
Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
Dec 11, 2006 | Candy AQ130 Front Load Washer
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
95 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
