Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Mp140 takes too many sheets
I have a brand new canon mp140 when i want to print one sheet the printer takes 5 or 6 sheets at once. Paper thickness lever is in the normal position but i have tried it in envelope and other positions but still same problem. Very puzzled with this new printer
    Sergeant:
  • 284 Answers
My printer pulls through up to 4 sheets of paper at once and then prints only on the top, so I'll have a printed sheet every 3-5 pages or a double sided print but with 3 pages separating the front and back...
Check your printer settings for paper thickness, ink quality, and check rollers for wear and dirt. Sometime if you change paper weight and finish , you will get better results
Jan 08, 2018 | Lexmark OfficeEdge Pro4000 - multifunction...
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
I have a printer canon inkjet mp140 and i don't know how to insert the paper from the tray that is down or from the upside tray
Well, you should insert the paper "from the upside tray". Follow these steps:
Align the edges of the paper before loading it;
Open the paper support of "the upside tray" and pull out the paper support extension;
Open the paper output tray ("tray that is down");
Adjust the position of the paper thickness lever;
Load the paper in the auto sheet feeder with the print side facing UP;
Align the paper stack against the right side of the auto sheet feeder.
Pinch the paper guide and slide it against the left side of the paper stack.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Canon R265 keeps grabbing 6 sheets for printing one sheet
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
Jun 15, 2009 | Epson Stylus R265 InkJet Photo Printer
What thickness of card can my canon ip4000 printer print onto
and the answer is:
standard paper: from a5 size (148.0 x 210.0 mm / 5.83 x 8.27 inches) to legal size* (215.9 x 355.6 mm / 8.5 x 14.0 inches)
* legal-sized paper is not loadable in the cassette.
bullet_s.gif non-standard paper: from 54.0 x 86.0 mm to 215.9 x 584.2 mm (from 2.13 x 3.39 inches to 8.5 x 23 inches) in the sheet feeder; from 89.0 x 127.0 mm to 215.9 x 297.0 mm (from 3.5 x 5 inches to 8.5 x 11.69 inches) in the cassette.
bullet_s.gif others: envelopes (european dl and us com. #10)
important
do not use the following types of paper. using such paper will not only produce unsatisfactory results, but can also cause the printer to jam or malfunction.
bullet_s.gif folded, curled, or wrinkled paper
bullet_s.gif wet paper
bullet_s.gif paper that is too thin (less than 64 gsm / 17 lb)
bullet_s.gif paper that is too thick* (more than 105 gsm / 28 lb)
bullet_s.gif picture postcards
bullet_s.gif postcards affixed with photos or stickers
bullet_s.gif envelopes with a double flap
bullet_s.gif envelopes with sticker flaps
bullet_s.gif envelopes with an embossed or treated surface
bullet_s.gif any type of paper with holes (loose-leaf paper is an exception; it is printable when loaded from the sheet feeder.)
* non-canon branded paper
Hope this does it for you, please -please leave a rating...thank you kindly
May 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma mp140 error 2 and the alarm light blinks. Help me. JJF.
try to reset your printer ---
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Mar 09, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon i560 colour printing problem
have you tried changing the cartridge..?
Jul 29, 2008 | Canon Office Equipment & Supplies
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
old marine
old marine
