Question about Panasonic PanaFlat LC50S (Beige) 15" LCD Monitor
Panasonic LC50S (TX-D5L31F)
Hi, My Panasonic LC50S (TX-D5L31F) monitor is not showing all texts clearly, and some texts on PDF files look really blurred. I am looking for an updated driver for this monitor. The one which is installed is from 2001 and I think that it is having problems working with Windows XP (service pack 2). Do you know where I can get an updated driver for this? I have tried driver sites, but they seem not to have the driver for Windows XP. Kind regards AitaSat
budmrtn
  • 11361 Answers
SOURCE: I have monitor PanaFlat LC50S
You cannot use higher resolution because the 1024 x 768 @60Hz is the max resolution for this monitor.
You do not need the driver since the USB ports are just the USB hub for expanding the USB prot from the PC.
This is 2004 mdel year, may be time to upgrade.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 24, 2010
Guru Guy
  • 95 Answers
SOURCE: Installing Panasonic DP-4510 to Windows Vista
Crafties is correct, most of the print drivers loaded onto the discs that comes with copiers were developed a few years ago. Try Googling "Panasonic dp4510 print driver vista" and see what you get. If one comes up listed under www.b2b.panasonic.com, go to it because its straight from Panasonic. I always have to search for the drivers for Vista on a new install.
Posted on Nov 16, 2007
SOURCE: Voice Editing 1.0 premium Update for Vista
Try this
Uninstall the software.
Reinstall the software
After installing the software update from Panasonic, plug your recorder into the computer. Go into 'Control Panel' and select 'Hardware and Sound'. Then Select 'Device Manager' and select 'Universal Serial Bus controllers'. You should have a device for 'Panasonic IC Recorder', it might be flagged yellow, right click on it and select 'uninstall'. Unplug your recorder from the computer, replug your recorder into the computer, the Device Manager screen will refresh and you should have 'Panasonic IC Recorder' back in the list. Try the Voice software, you should have in the drive list 'IC recorder'. Transfer your files.
It worked for me,
Pierre
Posted on Nov 19, 2008
SOURCE: I have SDR-H60, installed the videocam suite on my PC but cant us
The software will work only if you attach the camera to the electricity cable comes with the camer...The software will not work using the battery.
Posted on May 08, 2009
SOURCE: Video Cam Suite 1.0 does not work with Windows Vista 64 bit
Excuseme If I don't explain so clair, because I don't speak english well, but let me try that I did to solve this problem. First I installed a Virtual Machine(VMware Workstation 6.5.1) in miy Pc(64 bits) . Second, I installed a Windows Vista home basic(32 bits) or Windows XP Sp2 (32bits) on it., depending of what Operative sistem do you have in your real machine. And finally I could installed the Videocam suit in the Virtual Machine and everything was ok. I could transfer all my videos of the camera to the pc very easy The only inconvenient is that you need to transfer the videos downloaded of the virtual machine to the real machine with a flash memory or similar something.
Posted on Aug 25, 2009
I lost driver Panasonic TX-D5L31A-J Touch Screen.
This is the driver that supports the following panasonic monitors.
http://panasonic.jp/support/p3/display/download/ftp/disp.EXE
TX-D1734-J
TX-D14L31-J
TX-D7S35-J
TX-D9S54-J
TX-D5L31F-J
TX-9T55-J
TX-7F22-JN
TX-D2162-J
TX-D7F35-J
TX-D7P35-J
TX-D7S36-J
TX-D1F64MA-J
TX-D5L31TN-J
TX-15MA1
TX-D17P53-J
TX-D7F35F-J
TX-D1F63-J
TX-D5L31A-J
TX-D9L51F-J
TX-M7F22-J
TX-15MB1
Mar 03, 2011 | Computers & Internet
I cannot get the setup menu to show on the tv. Everything else is working fine.
I am not entirely clear on your situation because I don't know what type of cables you are using with this new receiver.
In other words, if you are connecting a TV that has HDMI inputs, (flat wide connectors) then you should connect it to the OUTPUT HDMI connector on the back of the receiver. (See the quick setup link below on page 2.
The new inexpensive HDMI cables have a lot of defective units, so cross check with other HDMI cables if you have problems.
If you are using conventional cables because the TV doesn't have HDMI I would connect the yellow cable output labeled "MONITOR" on the back of the receiver to the Yellow input (video 1, or line 1) INPUT on the back of the TV. Then set the TV to Video 1. Then you should get a display of the Setup screen.
Make certain that you push the "setup" button on the front of the receiver.
Below I've put in some links for either the very quick setup and the full manual.
I hope this helps,
Best Regards,
Mark
Quick Setup Manual Link
http://filedepot.onkyousa.com/Files/own_manuals/TX-SR606_QSS_En_Rev1.pdf?CFID=1396296&CFTOKEN=48521992&jsessionid=f030bbb9c220b0213d40674b2430783b5228
Full Manual Link
http://filedepot.onkyousa.com/Files/own_manuals/TX-SR606_En_A_Rev1.pdf?CFID=1396296&CFTOKEN=48521992&jsessionid=f030bbb9c220b0213d40674b2430783b5228
Jan 26, 2011 | Onkyo TX-SR606 Receiver
I have monitor PanaFlat LC50S Panasonic. My resolution is 1024 by 768 pixels and when i set it to bigger resolution my monitor gets line colours and i can't see nothing. And one more problem, i have usb...
Dec 24, 2010 | Panasonic PanaFlat LC50S (Beige) 15" LCD...
THE USER MANUAL FOR PANASONIC TX-28PK2 TELEVISION
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 28, 2010 | Panasonic TX-29PM1F 29" TV
Blurred picture
Have you tried lowering the Screen Resolution and Screen Refresh Rate of the PC in its Display Properties?
It could be that you PC's current settings are way above what the Samsung can handle.
Good luck and kind regards.
Thank you for using FixYa
Mar 22, 2008 | Samsung 793S 17" CRT Monitor
How to reset to factory default - to solve blurred text problem
Press the OSD enter button and scroll down to options. Factory reset is in the options sub-menu.
Dec 13, 2007 | IBM ThinkVision L170 17" LCD Monitor
Resolution of the text
What is the resolution that you are running the monitor at? There are two possible reasons that come to my mind.
1. You are running at a non native resolution. Based on your LCD spec you should run it at 1280x1024 resolution to have very sharp text as you normally expect from LCD's. However if you have set another resolution (say 1024x768) the text is blurred and this is a known issue with LCD's, which unlike a normal CRT monitor will get blurred running at any other resolution :(
2. You have not installed the monitor driver, hence again this limits your resolution and windows only allows you to select a resolution that is non-native (Meaning since the driver file is not there the operating system may not allow selecting the native resolution the monitor should run at). You can find the driver file at the samsung site. Its a common driver file for all LCDs.
Dec 12, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Bizhub C250/252 ICC Color Profile
HI i am fron DPI Grafica SH and have made test of diferents ICC profiles.
I will tell you how is my system to get to correct colors an sharp texts.
First - i print fron Adobe Ilustrator or Adobe PDF Profesional. If you have your file in Corel Draw export it to pdf or Publish a PDF File.
Second - I select s"sRGB IEC6 1966-2.1" this profile prints acurate fonts and colors that match whit de monitor. Is a little bit desaturate if you compare with " COATED Foagra". This one prints blurry fonts and blur edges.
This is the best result that i can get after print tests with all de ICC profiles.
Greetings and i hope that you can solve this problem.
Nolasco.
Oct 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Panasonic 50 inch plasma tv
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to: http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm Click on: Pictures of plasma symptoms It will direct you to a PDF file. It may not be your exact problem, but, it will show you which board will cause your problem. Hope this helps.
Apr 21, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Panasonic PanaFlat LC50S (Beige) 15" LCD Monitor Logo
318 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
