Question about Microsoft Windows XP Professional
HI Marked ya Marked and i saw MSCONFIG to know what's that exactly. but i didn't see any thing
  • Microsoft Master
  • 6,487 Answers
Not MSCONFIG, press CTRL+ALT+DEl and check what are the application running under Application tab and Pocesses tab, if its not there this can be a malware or virus that is causing this you may need to download and run this a good anti Malware its Malwarebytes...
Don't forget to rate the solution FIXYA thank you....
Posted on Nov 02, 2008
My computer wouldn't load so I took the safemode route,that didn't work,once I clicked on safemode it didn't go forward,this left me to reinstall (can't work through disability so I...
You could try using recuva, it is made by pririform,. you could go to their site and download it, this is the link http://www.piriform.com/recuva I hope this could help you recover most of your files. It does not recover 100% of your files but it is still worth trying.
Sep 05, 2011 | Computers & Internet
My right front burner wont turn off. My dad checked the control knob and it seems to be working. He unplugged it from the front burner and put it on the back to see if it did the same thing and it did. ...
with a model number to know exactly how power is supplied to the surface burners its going to be hard to let ya know anything definate...but do ya have knobs that ya turn to turn on the surface burners? if yes knobs..their will be terminals on the switch marked L1/L2 on those 240vac should be there all the time when turning the knob onto high on terminals marked H1&H2 should be 240vac to the burner
if it has the touch button to turn on the surface burners 240 vac into board all the time ..4 individual outbound power places (one for each burner) and the one for that burner also should have 240 vac when set to high
in either case if 240 vac out to burner the burner is bad
if 240vac into switch/board and not out..switch/board bad
Aug 26, 2011 | Kenmore 99123 Electric Kitchen Range
Ryobi table saw ...while being used...slowed down and stopped. the power switch bottom left terminal fried melted part of it and rendered inoperative
I had the same problem with my ryobi tablesaw.Because I didn't use the stand that came with the unit and was doing some heavy cutting-it didn't ventilate properly which caused it to overheat.My switch terminals didn't melt but the motor brushes housing melted.I could not repair it because what holds the brushes in place where melted away.You might be a little luckier and only have to replace the switch.It's very easy to do. Get another switch and follow the exact terminal wiring.The problem is that too much current is needed to cut your wood-whether the blade is dull,the wood is damp or too thick and possibly too much pressure is applied to the work piece and/or the motor has too much saw dust in it-blow it out with air pressure.Always let the saw do the work,otherwise too much current is going through that wire which powers it and heat is built up that the switch can't handle.
Aug 03, 2011 | Ryobi Garden
Put new decompression valve in , when pulling the pullcord there's no compression ,it justs jams
Check to make sure the old valve didn't have part of it fall down on top of the piston. I just had that exact thing happen to a TS400 in my shop for service.
Jul 12, 2011 | Stihl Ts 410 420 Cut Off Saw...
Can't get blade screw off, is a circulat saw brand Rayobi.
Hi delauz1939,
You didn't say exactly what the problem is. Is it that the bolt is too tight or is it that the spindle won't stop turning?
If the problem is that the spindle turns so you can't get the bolt off, there is usually a spindle lock on Ryobi circ saws. It is between the handle and the blade guard. I believe it has a label on it.
If yours doesn't have one, like my saw, what I do is jam the blade so that it won't turn and then loosen the bolt.
If this is not the problem, please reply back.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 17, 2011 | Saws
Problem with Epson CX5000 Scanner
1) Place your portrait on the glass face down.
2) Press the button marked "Start B&W" for a black and white copy, or press the button marked "Start Color" for a colour copy.
If you still have problems, it's very clear on the manual - page 7
Feb 21, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Hi Marked; I know I know what the difference betwen MSCONFIG and Task manager I fixed the problem and killd the virus. after that I got this msg. if you can pleas.
OK sorry about that but what I'm saying is since your computer was infected by a virus there's also a possibility that its infected by spyware and malware that's why I advice you to use malwarebytes because its a good software and really help alot in removing spyware and malware that can cause this type of problem....there';s no harm in giving that solution a shot right since we're trying to fix this problem...
Nov 02, 2008 | Microsoft Windows XP Professional
Corrupted msconfig
click on start
select Run
type MSCONFIG press enter
click on startup tab and repair it by removing the check marks on the items u don't want to be started automatically
NB: make sure you know exactly what ur doing it can be messy there.
Mar 06, 2008 | Microsoft Windows XP Home Edition
Mag LT561 Lcd monitor
Simply try replacing ALL the large Value Electrolytic Capacitors on that board, 1000uF, 470uF, 330uF, 220uF, they are "the big fat round blue things" marked with say 1000uF 16Volt or the like, get the EXACT same ones and replace them... this may indeed fix ya uint. Good luck.
Jul 07, 2007 | Mag Innovision LT561D PNP Monitor
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
