Question about Goldstar GVR-DD1 VHS VCR
When 8mm tape is inserted I get an immediate "alarm" display
After working perfectly my long time, used unit is showing the word "alarm" as soon as a 8 mm tape is inserted. It will neither play nor fast forward or reverse. I looked in the manual and there is no reference to this. thanks, Mark
  • 4 more comments
  • ahsim Mar 01, 2008
    When 8mm tape is inserted i get an immediate alarm display and nothing works.
  • samshaw176 Jan 14, 2009
    When I insert the 8mm its immidiatly ejected or I get "alarm"...
  • Kingpole Jan 28, 2009
    I have the exact same issue with mine.  "Alarm" displays when I insert a tape.
  • bewleygary Mar 21, 2009
    When I insert 8mm tape into Goldstar GVR-DD1 player it accepts the tape but immediately displays "alarm" & nothing works on the 8mm side. I took the cover off but could not see any aparent problem. The only belt I saw was intact & still working. Does anybody have a solution for this problem? bewleygary
  • KP Hathaway May 05, 2009
    When I insert an 8 mm tape I get an "alarm" comment on the display. It will not move tape either FF or REV or Play.
  • samshaw176 May 11, 2010
    Its a player with VHS and 8mm
I had a problem with my 8mm drive where it could not reliably play, rw, ff, or eject tapes. The problem was the capstan motor. This is the motor to the right of the playback head of the deck that drives the tape forward and backward. It is flat and about 1.25" in diameter. The problem with the motor was that the metalized coating around the magnet had delaminated and was hitting the stator windings. At first I could manually move the motor with my finger in either direction with no detectable drag or friction but as time went on, the motor became worse and worse to the point that it would snag and only go in one direction. At this point I knew my problem was the motor and not an electrical problem.
The fix was relatively simple. I removed the 8mm deck from the unit and then removed the capstan motor by flipping the deck over and removing the three screws retaining it. Also disconnected the flex cable from the motor to the deck circuit board. The connector is on the bottom of the board. Just pull it gently upwards away from the board.
The rotor of the capstan motor can be removed by carefully removing the plastic drive gear from the motor shaft by forcing off the shaft. Then lift the rotor off the stator assembly. It will take a little but of force to remove the rotor due to the magnetic attraction of the rotator to the stator. Once removed, the problem in my case was obvious. Large pieces of the metallic coating of the rotor were peeling off and hitting the stator.
To remedy the situation, I peeled all the coating off and then used adhesive tape to capture all the loose metal filings that were attached to the magnet face. I kept applying and removing fresh tape until all the filing dust was removed. Once clean, I used a light coat of finger nail polish on the now exposed and cleaned magnet surface to act as a (small) protective barrier.
Reassemble everything in reverse order. When done, my deck worked great.
Posted on Jun 16, 2009
  • 579 Answers
Is this a player or a camcorder?
Being a long time used unit it probably needs its rubber parts serviced which is consistant with your problem.
Posted on Dec 28, 2007
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
TEAC R-H300 Forward Play Fault
The unit need some work by a technician. The bad thing about the drawer type decks is that it makes it hard or impossible to clean the tape path. I have not seen one of these but I could probably fix it.
Some of your description sound like a loose capstan belt and then other times the Pinch roller is not engaging- they may be related if the mechanism is tied to the capstan motor system.
Sep 11, 2012 | Teac R-H300 Dual Cassette Deck
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
SONY DIGITAL 8 DCR TRV-740E ERROR C:21:40
This is an indication of a motor failure. There are a number of reasons for this problem. This unit should be brought in for service. There are no user servicable parts inside and working on these in not recommended without training. Expect a repair cost in the $150 range.
Dan
May 02, 2008 | Video Cameras
Transferring camcorder tapes to VHS
It depends on what speed these tapes were first recorded on. Maybe the camcorder your trying to use to play them back do not support this tape speed I have seen this in the past. Are these 8-MM or VHS-C tapes.. Also the tapes that were recored, maybe tyhere was something wrong with the tape path and was slightly out of alighnment. I had once a Sony 8-MM camcorder and tapes a lot of stuff and then gave them to someone to watch and they would not play. I tryed the tapes again in my camcorder and they worked great. I got a test tape and tryed it in my camcorder and it turned out the tape path alighnment was off, so i had to rerecord everything I had from one camcorder to DVD so i could fix my camcorder. Good Luck
Mar 26, 2007 | Hitachi VME545 Camcorder
I am having trouble playing a Hi-8 tape in my sony camcorder DCR-trv250
Looks like you have a blank area in the Tape. Try Fast forward and you will get again MM:SS:SS.
Mar 25, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Televison & Video Logo
355 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
