Home | Clock Radios | Accuwave DS Clock
Clock Radios
Problem for Clock Radios
Generic problem for all Clock Radios
Accuwave DS Clock
By mchoy on Nov 02, 2008
I have a Howard Miller Accuwave DS atomic clock but don't have the manual. I tried pushing the "receive" button to update the time, but it does not reset the time back 1 hour for daylight savings time (PST). How do I set the clock for the time? I thought I just push the button and it sets itself. After I push it, the little radar symbol comes on and it appears to be receiving, but nothing happens. There's a small pin hole in the back of the clock that says "reset", should I use a pin and push it?
Thanks for any help!
Mitch
Comments:
Nov 02, 2008
- Opps, the model number is 625 - 236.
Nov 04, 2008
- I took the battery out for 1 minute, replaced a new battery in the clock and placed the clock outside in the back yard to get a stronger signal. After leaving it poutside for a few hours, it reset itself to the correct time!
Thanks for the help!
Same Problem
Nov 29, 2008
-   Does anyone know how to set the Howard Miller Accuwave clocks to Hawaii Standard Time or is it not possible? We recently moved to the islands and I would love to be able to still use this clock. Any ideas?
-   jenhorgan
Nov 10, 2008
-   i have the same problem. i set my clock and i cant seem to get it off pacific and every night it will change 2 hours behind. i am in central time zone-   cday697
Nov 04, 2008
-   I have "analog" Accuwave DS clock with hands, not digital. Does someone know how to set time? How to adjust for DST?-   ocean33
Best Solution
posted on Nov 04, 2008
Very Helpful)
kygal5
Rank: Apprentice
Rating: 100%, 9 votes
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Was this helpful?
Yes
No
8 people thought this was helpful
Popular Solutions for Clock Radios
Questions and Unsolved Problems for Clock Radios
Answer
radio for use in bedroom. Very poor reception so intetrnal aerial is not suitable and it will be... (More)
Answer
how do i change the time??????
Answer
my daughter has changed the time to military time 20:14 How do I fix it back?
Answer
House call for Hershede tube gradfather THANK YOU Bob Johnson 760-366-8888
Answer
Dear Sir My Bose will not read any CDs. I insert them and it says disc error on all of my CDs. Hope... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Clock Radios:
Top Clock Radio Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Clock Radio Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
