No picture or sound
I put a new chip in to solve shrinking and expand screen.When I went to turn the TV on I got nothing. The light is on in the front but have no sound or audio.Everything is connect.Model# 9P5531 C102, Serial# 28799697.
PhillipsMagnavox projection
  • 3,459 Answers
Put the old chip back in...does the shrinking/expanding problem return? If so the new chip may be faulty.
If the problem stays the same - no audio/video  - check your soldering, cables, etc.
Posted on Nov 14, 2008
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Picture Shrinks and Expands
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
How to adjust picture on projection TV
It should have in the menu ,under settings ,, convergenge,, it realines the colors,, ,,
Oct 03, 2008 | Philips 60P8341 60" Rear Projection...
Magnavox 60
which chip did you replace? and what is the model number of your set?
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
TV Screen
If it shrinks and expands over and over it may be the opt chip. Otherwise its likely a convergence chip problem. Check www.magnavoxhelp.com to see if they have a kit for your set.
Aug 12, 2008 | Philips 60PP9202 60" Rear Projection...
'42 Magnavox television won't show picture
I had the a similar issue. But on mine the first symptoms I had was that the screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no video but the power light was still on.
I gave up and called in a repair tech. He fixed my TV in less than 30 minutes . I put together a how to guide and parts kit to help others solve the same problem.  Not sure if it will work for you - my set never made the clicking sound - but it may be the same issue. http://www.magnavoxhelp.com
Jun 20, 2008 | Televison & Video
After power on TV the screen shrinks to (50%) and then back out to (100%) back and forth for about 15 minutes
the quetion is:  have you checked your format/aspect settings? if it is on auto-format, picture size will vary due to program you are watching.....or is it a raster/width problem? The thing about the time on digital clocks: daylite saving time usually started last saturday, the federal goverment changed it, the fall back time is now this saturday! Most newer digital clocks auto-change according to old schedule....( not sure if you were aware of this )  let us know whether a width problem or what......
Oct 30, 2007 | Philips 9P5544C 55" Rear Projection...
Phillips 51pw9363 51in
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Oct 25, 2007 | Philips 9P6040C 60" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
