Question about Dishwashers
Hotpoint DF21P Not taking water. Valve has continuity, but thats all.
How do I get into check the pump for blockages on my hotpoint wmud942 washing machine, the key symbol is on all the time with door locked, when a programme is running the pump starts but then when it
I would suggest you fill the washer with water externally up to below the door level and run it in one of the short wash cycles. I would assume it will progress further into wash. This would suggest the inlet water circuit has a fault. I am hoping the laundry water tap was turned on when you were running the washer.
Best to replace the inlet valve and see. Worth spending the 20 quid.
Hotpoint WMUD 942 UK Washing Machine Valve
Sep 07, 2014 | Hotpoint Washing Machines
Hotpoint fdf780 flooding at rest
Ya you're right the problem is in the water inlet valve, but try to consider also that this machine is equipped with a digital controller or a so called IC. Better to consult a technician nearest you.
Feb 01, 2014 | Dishwashers
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Cold water inlet flow is low and constant. do i need to replace the 'dual water inlet valve'?
Hi, Yes....
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Sep 05, 2011 | Hotpoint VBXR1090B Top Load Washer
Water continues running even when machine is in off position,Water fill is at very slow rate.
The problem is the water inlet valve has failed. It will need to be replaced. They sometimes fail when they get rust and debris inside, then they do not seat properly. They are inexpensive and easy to replace. Here is a link that should help water inlet valve replacement
May 27, 2011 | Hotpoint Washing Machines
Dishwasher wont take in water but pump is working, had side off and checked in coming supply. could it be the electronic valve on the supply in?
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Sep 24, 2010 | Hotpoint 24 in. DF55 Free-standing...
Pumps water out but not water in to start cycle
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models.
Apr 07, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Ice maker won't make ice but the water outlet works
Either the water valve is bad or the icemaker is bad.
Check the water solenoid valve at the back, bottom of the fridge with an ohmmeter. Remove the wiring harness from one valve at a time and check it for continuity. If it has continuity, it is good. If there is more than one valve, check them all, one at a time.
If they are all good, the icemaker is bag.
Mar 03, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Hotwater runs continuously
It sounds like a little piece of trash (precipitated solids in the water line) have gotten in the water valve, or, the fill switch has failed.
If you know how to use a voltmeter, then see if there is voltage always applied to the water solenoid. If not, the water solenoid valve is bad. If it does have voltage all the time (when it's not supposed to be filling) then it's the fill switch.
Feb 01, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint is not taking water inlet
If your thinking air in the water supply line, air won't be the cause. I would look to make sure there is not mineral buildup inside the valve, and that the valve is good.
Turn the water off, disconnect the line at the water valve, then carefully tirn the water abck on to make sure there is good flow from the water supply line. If there is, then look toward the dishwasher side. If not, look toward the water supply side.
Jan 24, 2009 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
