Question about Kitchen Ranges
Removing oven door kenmore elite 790.46709600
  • 59 Answers
I believe on this particular model when you open the door on the hinge there are little tabs that flip out. these will prevent the door from closing and allow you to remove the door by closing it as far as it will go (with the tabs preventing further closing) and then pulling up and out on the door. Good luck!
Posted on Nov 02, 2008
SOURCE: Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Posted on Dec 21, 2007
  • 148 Answers
SOURCE: Kenmore elite 790 79363400 dual fuel oven door does not close all the way a
if your locking it to make the light goes off it sounds more like the light switch on the oven needs to be replaced
Posted on Jul 08, 2008
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
  • 31 Answers
SOURCE: I have a Kenmore Elite Gas Range. #790 series.
Possibly a malfunctioning electric gas valve. The electronics may be sending the message to open that valve, however it could be stuck, clogged or, worse, the electric servo that manipulates it could be fried (no pun intended).
Do you have your exact model #? {Not serial} I can research where to troubleshoot a valve problem or an electronics issue.
Posted on Jan 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: Installed new EOC for Sears Kenmore Elite 790 46609500 oven.
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    How do I opening a lock door on my Kenmore Oven? Model #790.95599102
    we lost our owners manual for our kenmore elit smooth top range and forgot how to use the self clean oven.
    May 10, 2010 | Kenmore Microwave Ovens
    New Kenmore Elite hood unit. White in color. Bottom exterior door trim is developing cracks along length of door. Is this an isolated problem?
    It is not widespread... more than likely from your oven below.
    Mar 31, 2010 | Kenmore 62622 Microwave Oven
    Aluminum melted on bottom of double oven Kenmore Elite
    Scrape it. DO NOT USE until it is removed.
    Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite speedcook oven Model 63799. F2
    f2 error means : -------
    1. The oven temp has risen above 665F and the door is not locked or
    2. The temp has risen above 965F with the door locked
    ------------- if this happens you should check: -----------
    1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
    2. Check and replace oven temperature sensor if necessary
    keep updated,please do accept and rate the solution.thanks.
    Sep 30, 2009 | Kenmore 63792 Microwave Oven
    DOOR ON KENMORE ELITE IN LOC POSITION AND CANNOT CLEAR
    unplug for 40 minutes and re-try.
    Aug 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Oven door won't unlock
    I had this same issue and consulted the owner's manual. Once on self clean it takes up to 3-4 hours for it to automatically unlock. It is a built in safety feature of the oven.
    Jun 21, 2008 | Kenmore 46123 Stainless Steel Electric...
    Kitchen Ranges Logo
    703 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
