Question about Sport & Outdoor - Others
1983 yamaha excel 3 snowmobile won't start.
I have checked to see if it is getting fuel to the carb and it is. It doesn't seem to be getting any spark. I have an old service manual but it doesn't get into detail very good about alot of stuff especially electrical. Does anyone have any ideas on what to check and do you know where I can get an actual repair manual. Thank You.
I had that problem with mine and foound out that the tether kill switch was not completely seated. Once we had it plugged in solidly, it fired right up. Something to check.
Posted on Dec 17, 2008
My carbs on a XJ900 are leaking from the return pipe , those 2 pipe are one between the first and second carbs , and the second between the third and fourth carb , the float is ok , everything seem to
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
No 3 and 4 carbs leaking from overflow pipes HELP
Carbs leaking Here is how to fix it
Yamaha 95 XJ900S Service Manual
OEM parts for Yamaha
Yamaha diversion 900 XJ900S Owner Manual
Apr 28, 2014 | 1985 Yamaha XJ 900 F
Yamaha Venture snowmobile 1991 fail to start and idle
before you start on the carbies . use a bottle of metholated spirits in the fuel tank. IT breaks down the surface tension of water and allows it to be drawn through the jets . IT is combustible the same as fuel and will not harm the engine . If you have a drain on the carby bowel then drain out ant water first.
Feb 15, 2014 | Cars & Trucks
Snowmobile troubleshooting
Sounds like fuel supply, most likely bad diaphragm in fuel pump. Start by making sure gas free flows from tank to filter, I would replace filter as it gets overlooked then it should go to fuel pump then carbs. Good luck!
Feb 24, 2018 | Winter Sports
My yamaha v-star won't start
Have you cleaned the Fuel tank recently? some times even under excellent care you can get gunk built up. also have you checked spark plugs
Jun 09, 2012 | 2005 Yamaha V Star 1100 Classic
Yamaha royal star xvz 1300 won't idle without choke
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
I have a 1983 yamaha virago xv500 and i am having problems starting it when its cold and keeping it running. i have great spark and fuel it flowing from the tank and the carb seems fine. i am not sure if...
Hi, Johnnyac15 and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ViragoTechForum com Yamaha Virago XV Forums That Rock
http://www.motorcyclesurvey.com/reviews/yamaha/virago_500/r1128/comments/page-2
1983 1987 Yamaha XV500K Virago Service Repair Manual XV500 PDF Preview... $10
http://mybikemanuals.com/yamaha/yamaha-xv-owners-manuals
Jun 23, 2011 | Yamaha Motorcycles
I have a 1979 yamaha 340 enticer.Recently it would not start, no spark. I tried new plugs and a new ignition coil but still no spark. Don't know what to do next.
Hi, Gmgroot and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1999 royal venture no spark limited knowledge need help
https://www.tradebit.com/filedetail.php/55384194-yamaha-1983-1988-enticer-excell-340-snowmobile-service
http://vintagesleds.com/library/manuals/yamaha/1980/ET340_80.pdf
http://www.gearhead.com/snowmobile/parts/oem/yamaha.html?aribrand=YAM&s2=snowmobile
Feb 04, 2011 | 2000 Yamaha Royal Star Venture
I have a 1983 cb550sc honda that has a starting problem. when it's cold it only runs on no.1 cyl and all other exh pipes are cold. i have checked all systems and can't find the problem. compression is...
I certainly wouldn't rule out a fuel restriction, either in tank where fuel drains to line, or line(s) to carburetors. When cold, more fuel required, plus once engine starts to run, vacuum from carbs may overcome restriction, as well as less fuel required. My guess is that heavy acceleration is a problem even when warm as well. Doesn't take long to check in tank to see if filter/screen in tank is plugged at all, as well as remove fuel line for carbs and use compressed air (carefully) to clean out line(s) as well as blow back into tank to dislodge debris at screen in tank, but if there is debris, remove tank and flush good. Any in-line filters should be replaced as well.
Aug 26, 2010 | 1983 Honda vt 500 ft ascot
I have a yamaha excel V snowmobile. It has been sitting for about seven years without being started. A couple of days ago i got it running but it has to be at full throttle to go anywhere. the overflow...
Get yourself a manual, go to this site and source one (freebies). After that it should be smooth sailing. Your problem sounds like a sticking needle and seat, but I do not know whether they are present in your carby.
http://www.yamaha-motor.com/sport/service/viewmanuals/viewmanuals.aspx?ls=sport
Feb 04, 2010 | Yamaha V-Max Motorcycles
Sport & Outdoor - Others Logo
657 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
