Question about Aiwa XR-MN75 CD Shelf System
Standby light flashing..won't turn on..
I switched from using the aux input from a computer to record player on an aiwa xr-mn75 system. After doing so the on 'light' is flashing. There is no response from the system apart from the flashing light. Any ideas! is it knackered?!
  • cjretamal Jan 12, 2009
    I'm using a translator. I also have the same problem with my player.
    You've solved the problem? please help me! my email is
    cjretamal@gmail.com
5 Suggested Answers
mnelsonix
  • 58 Answers
SOURCE: Aiwa z-l700 won't switch on?
1. Verify you really have power at the outlet. If so...
2. You will need to open up the main boby of the device (amp portion).
3. On the circuit board where the power plug comes in, you need to look for a fuse or fuses. Do you know how to check these? This is most likely the problem. Good Luck!
Posted on Apr 07, 2009
  • 133 Answers
SOURCE: where do I get drive belts for a aiwa xr-m10
Try eBay, i've been looking for these on the internet, they sell kits (long and short variety), containing several pairs of different measures (about $7 per kit), and are supposed to fit various brands and models (including aiwa).
...a hint: a belt measure tells you the diameter of the circle formed by that belt
...another hint: old belts are loose, which means they are a bit longer than the new ones, so when you select the new belt from the kit, it should be a bit shorter than the one you removed from the deck (old belt - bigger circle, new belt - smaller circle).
I'm aware that not all aiwa models are the same, the one i was repairing a while ago had a double tape deck, each deck containing two belts, one long and one short, they were a bit tricky to change, but i didn't need to disassemble any of the mechanisms, i just had to remove both decks from the housing for easier access to the belts which required prior removal of the top cover and rear panel. After that it was some 4 to 6 screws and 4 connectors (just about half less in your case, i believe).
I can't tell what your unit looks like on the inside, but in my opinion aiwas are relatively easy to take apart, but then again, i could be wrong...
Hope this helps you get closer to a solution.
regards
3rq8 (Triarcuate)
Posted on Jul 17, 2009
  • 19 Answers
SOURCE: how do i open the speakers on Aiwa XR-EM50 CD
on most speakers like this you will Pry the Grille Off and the actual speaker drivers can be removed by loosening screws holding them in the enclosure.
Posted on Oct 26, 2010
SOURCE: aiwa xr-em220 standby light flashing but not powering up
try checking that the wire is secured in all components. then retry to use
Posted on Mar 16, 2012
How do I record on tape from the micro?
That's because "micro" and AUX are inputs.
Feb 25, 2016 | Aiwa LCX-330 Shelf System
Playing MP3
Should be able to with a headphone jack to rca cable. Does the shelf system have an aux input on the back?
May 29, 2013 | Aiwa Audio Players & Recorders
How to connect an aiwa music system to sony dvd player
Just plug the audio output of the DVD to audio input(AUX) of Aiwa system. Select the player in the Aiwa( Aux, DvD, and Phono)
hope that helps out!
Jun 09, 2011 | Aiwa Audio Players & Recorders
I have a aiwa xr-avh80 i want to attatch my mp3 player so i can listen throgh the hi-fi how am i supposd to do this and what wire i will need
Your Aiwa must have an input socket such as tape, CD, or Aux at the back or you won't be able to connect it.
If it has an imput you can get a Dock for it. This will keep it powered up so you don't run the battery down while you are playing it.
Another way and much cheaper is to get a 3.5mm Jack plug to two RCA phono plugs lead. These are widely available from your Hi-Fi dealer. All you need to do is put the RCA plugs in the input of your Aiwa and the Jack into your headphone output of the MP3 player and presto job done!
Feb 21, 2010 | Audio Players & Recorders
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
I connected an external MD to Aiwa XR-EM220 but it doesnt work...
If I remember correctly its the button on the front that says AUX, if not then check with the website and find out for sure http://www.us.aiwa.com/default.asp?page=support&browse=yes&cat=7
Feb 29, 2008 | Audio Players & Recorders
Aiwa XR-MN75 CD Shelf System Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
