Question about Kenmore 73952 Gas Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
I have a kenmore front load gas cloths dryer whose model number is 97273100 72731 and serial number is MB4321932. This morning I found that it tumbles and signals when the drying cycle is over but the cloths are not dry, from which I infered that the heating part is not working.
What should I do about this and is it self fixable?
  • bgdd0 Nov 02, 2008
    I have the same problem... exactly... My dryer (73592) was working yesterday no problems. Today I put some laundry in and the drum turns...and the cycles sounds when over... but there's no heat. The duct is clean... the lint screen is clean.... are there any fuses that I can check?
Check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Posted on Nov 11, 2008
My 600 series Kenmore dryer will tumble clothes but not heat-dry them. This happened during a too-large load, and it hasn't heated on any size load since then. I was thinking the heating element might...
send model number and also you'll need a meter to do some checks for me,i'll be happy to work with you but need model numberalso is it gas or electric,if the lint filter is inside you can do everything from the front.
Sep 21, 2013 | Dryers
My kenmore dryer 70s series wont start
send the model number,open the door and look around the opening where you put the clothes in,you'll see a tag with model and serial number,just need model number.
Mar 18, 2013 | Kenmore Dryers
Kenmore quiet pak 1 heavy duty king size front loading dryer is not heating up, but is tumbling fine. Desperately seeking manual.
Go to www.repairclinic.com and enter the model. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Kenmore video showing disassembly.
Nov 24, 2017 | Washing Machines
We have a front load Kenmore dryer that is about 10 years old. Its model number is Mod 110.62994102. Our dryer takes forever to dry clothes. We have cleaned out the vent in back as well as the exhaust...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Dryers
My dryer will not heat at all to dry my clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
Kenmore Gas Clothes Dryer does not heat sufficiently
Ok, first and foremost, make sure your vent is clean and clear.
If the vent is clean and free of obstructions the most likely culprit is your gas valve coils. When they fail the typical symptom is heat at the beginning of the cycle and no heat about 20 minutes later.
If you can, post the complete model number from the dryer and I will give you step by step tear-down and replacement of parts instructions.
Jun 27, 2010 | Kenmore 63942 Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
1,102 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
