Question about Dualit CTS4E 4-Slice Toaster
How can I clean the inside toaster rails
I had some type of cinnamon bread melt all over the toast rails - it's sticky & gooey, but I can't get inside to clean them?
  • Anonymous Dec 31, 2008
    I've got to say the post above is rubbish! What use is industrial toaster cleaning guidance for a non-commerical (home) toaster?
  • 51 Answers
Hi rsands1,
The following link will help you maintain a clean and good toaster,
http://www.pnwb.com/Toaster%20Maintenance%20Parts%20.pdf
Thanks.
Posted on Nov 02, 2008
Why does my toaster ony toast one side of the bread
Because the nichrome wire on one side of the toast has broken.
Its time to get a new toaster.
Mar 17, 2015 | Baking
I have a pink two slicer kitchen aide Toaster. The button to pull down the bread to toast will not stay on. Where can I order/buy a new pink one? thanks kathie
Before tossing out the toaster, check on the inside of the toaster, you may have a wire bread closure in there that is blocking the lever.
I took my son's toaster apart when they replaced it, and found a bread closure inside it, blocking the lever. Anything small enough to fall inside could do this too. (The toaster works fine now, and I use it myself!)
Make sure you unplug the toaster first, you don't want to have a "shocking" experience.
Turn the toaster upside down and shake it a few times, over the kitchen sink, and then open and clean the "crumb" compartment.
Sorry to tell you this, but, your toaster is no longer available on the market, you might want to check a few thrift shops in your area...or you can check this link for another model that is pink and a KitchenAid.
http://www99.shopping.com/xPP-toasters--kitchenaid~S-213~OR-0
Oct 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
How do you get melted sugar off inside of toaster?
use a damp cloth tied on a brush/stick to wipe the sugar residue off the bars. If it still does not help, then soak the cloth in lemon juice and scrub on the bars as it would also wipe out the sugar and would not affect the working of the toaster.
Dec 21, 2008 | KitchenAid KMTT400-SS 4-Slice Toaster
Odor from toaster
ozone smells like fresh sweet air ( same smell as after a lightning strike )
what you probably have is the smell of melting plastic from wires in the toaster
Apr 06, 2017 | Kenmore KTES4 4-Slice Toaster
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Dualit CTS4E 4-Slice Toaster Logo
1,280 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
