Question about RCA P46924 46" Rear Projection Television
32" Trinitron warms up picture goes black
Hi, I have a 32" Sony Trinitron. The picture is great but after a short time (a minute or two) the image starts to deteriorate. Blacks lines appear on the screen and seconds later the image fades to black. If I turn it off and on the same process happens again, only quicker because the set is already warm. I would say that the tube is fine given that the image is good...even if only for a few seconds. Could it just be overheating? Capacitors? Does it just need cleaning or are we talking about some real $ to service it? Thanks for the help, Strobelight
    Sergeant:
  • 337 Answers
You need to call for service now that the unit still turns on,the problem will become expensive if you try to use it like this,right now the set might have loose conections in the power supply,horizontal driver transformer.ETC.Be safe and call a service tech.
Posted on Sep 25, 2006
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony pre-LCD 32" receives power and directly
I would take your A/B switch out of the line. And get yourself a good reciever to channel every thing.
Jan 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture was great day before, next day picture would not come on.
I had the exact problem. Turned it off at night, next day nothing. Set is KV32FV16, manuf. in 2000. Repair tech. found bad fuse that was all, set now working. Fuse located in lower right hand side of chassis. Fuse appeared to have deteriorated rather than blown. Good luck.
Mar 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture goes black on and off but sound still on
This could be a sign that the picture tube is starting to fail. To prove this try the following: Please note that there are potentially dangerous high voltages present inside the set, so be careful.
Unplug the set and remove the back. Locate the flyback transformer (lower right when facing the back of the set and has a lare red wire coming out the top.) There should be 2 controls on that part. One should be labeled screen the other focus. Turn the screen control slightly clockwise. Turn on the set. If the blanking stops, then this will "fix" the problem for a short period. This is not a final fix, but a short tern remedy to give you time to locate a replacement set.
If the above does not resolve the problem, please update this and we'll investigate further.
Thanks,
Dan
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, has sound
This problem usually lies on the horizontal output transistor, try to check also for shorted diode. you can buy ftom any electronic parts dealer or radio shacks stores
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv-32fs13 32''
when the lights flash those are codes that tv repair men have.youd be better off buuying a new tv,they are less than 500.00 nowadays
May 20, 2009 | Televison & Video
No picture, Standby blinks then goes out
Sony Trinitron XBR
Problem/ Standby Flashes Power button
Aug 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA P46924 46" Rear Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
